m50434
1
Hi there,
is there a possibility to set a timezone in Flux (like the way its possible in SQL-Query influxdb: for example tz(‘Europe/Amsterdam’) ??
I know there is an option: Options | Flux 0.x Documentation
But I have no idea how to use this in my flux-query.
m50434
2
Damn: I didnt see the link is marked with [IMPL#XXX]
So it isnt implemented yet
rawkode
3
For now, you can use offset
Hopefully tz added soon
m50434
4
Thanks.
Actually Im using the aggreageWindow-Function… and there is no offset-option available. At now Im using timeshift…
I tried the window-function with offset as well.
Suprisly the offset doesnt make any change to my data. No idea why.
rawkode
5
Timeshift is the better way to do it! It was added recently though, do I wasn’t sure if you had access to it.
That’s great. Hope it does what you need
