I have an integration with OpsGenie, which OpsGenie in turn notifies my team on Slack that something has gone wrong. This is working fine, but I can’t figure out how to change the description. Currently my alert looks like this. The message or title of the alert is what I expect. Jenkins job failure -> name_of_the_job
However, the description is something completely useless for us, because I think that’s the row that generated the alert. I want that to be a link to our Jenkins instance, so that we can navigate directly to our job.
I’ve tried adding the expected value on the .details() function like this:
|alert()
.id(idVar)
.idTag(idTag)
.levelTag('level')
.messageField(messageField)
.durationField(durationField)
.message('Jenkins job failure -> ' + '{{ index .Tags "name"}}' + ' | BI Prod')
.details('Failing job link: https://jenkins.prod.bi.auto1.team/job/' + '{{ index .Tags "name"}}')
.warn(lambda: "last_result" > 0)
.warnReset(lambda: "last_result" == 0)
.opsGenie2()
.stateChangesOnly()
But that didn’t work, the notification is still the same. I also tried doing it with HTML instead of just a string, but that also didn’t work.
Is there a way to change the description on the OpsGenie alert? I can’t figure it out, and I feel documentation is not clear on how to use with TICK.
I have the notion that it might be because we’re using Chronograph to configure the OpsGenie integration instead of a kapacitor.conf file, and Chronograph doesn’t have the details parameter as specified here: OpsGenie v2 event handler | Kapacitor Documentation, so I’m assuming the default value is false.
Any thoughts on how I can achieve this?
