Sent alert check deadman to email?(no third party service)
its possible?
thank you
its possible?
thank you
i see this post:
nothing change?
Hello @Mark_influx,
Have you had a chance to take a look at these docs?
thank you @Anaisdg is see that page in documentation but is all with third-party i search a metod to sent email or notification into a mail with local smtp
i see this method is possible to personalize with script with local smtp?
https://www.youtube.com/watch?v=LfWVZHuCCnE
at minute 54:00 at the moment is the best i see but use rbox(third-party)
better option is use local smtp
thank you
Hello @Mark_influx,
That example uses Flux in the background.
All checks, notifications, and alerts use Flux.
Specifically that example takes advantage of
thank you i try whit notification with webhook by google but doesn’t work…with rbox works fine…
i have 2 question:
thank you
Hello @Mark_influx,
Do the examples in the docs not help? What type of http.post() example are you looking for?
You can run http.post function just as a query (as you would do in the data explorer in the InfluxDB UI for example) and send a single notification. You don’t have to include it in a task, but people usually do.
Hello @Mark_influx,
Can you successfully send a message in the data explorer?
//replace with your parameters
import "http"
http.post(
url: "https://us-west-2-1.aws.cloud2.influxdata.com/",
headers: {"Content-type": "application/json"},
data: json.encode(v: "foo"),
thank you @Anaisdg i try but nothing sent…
i made a mistake?
this is the code:
import “http”
import “json”
from(bucket: “rasp-pi”)
|> filter(fn: (r) => r[“_measurement”] == “Ora-esatta”)
|> filter(fn: (r) => r[“_field”] == “valore”)
|> yield(name: “mean”)
http.post(
url: "https://chat.googleapis.com/v1/spaces/AAAAn_JQKSY/messages?key=AIzaSyDdI0hCZtE6vySjMm-WEfRq3CPzqKqqsHI&token=RTqCM7iiSE0cjpc0LNnfjW3sEyEkmeARSOWIb6_3jDM%3D", headers: {"Content-type": "application/json"}, data: json.encode(v: "mean"),)
no anyone send notification via mail or google webhook ?
