Hi guys, I have a question for you.
Is it possible to display all the buckets from my existing InfluxDB databases in a new InfluxDB database? I want all the buckets from my current databases to be visible and accessible in the new database.
I’d say only if you clone your database, I’m not aware of the possibility of a virtual link between databases/buckets.
If you want to populate multiple databases just do so in your client (if you use Telegraf just use multiple outputs)
