Hi guys,
Am new to Influxdb & telegraf connections. Currently am trying to send data to multiple tables of the same database via telegraf & MQTT but I couldn’t find any help on this. So far I can send one data to a single table. How to send multiple data to multiple tables?
My code is below
# OUTPUT PLUGINS #
# Configuration for influxdb server to send metrics to
[[outputs.influxdb_v2]]
## The full HTTP or UDP endpoint URL for your InfluxDB instance.
## Multiple urls can be specified as part of the same cluster,
## this means that only ONE of the urls will be written to each interval.
# urls = ["udp://localhost:8089"] # UDP endpoint example
#urls = ["http://localhost:8086"] # required
urls = ["http://127.0.0.1:8086"]
## The target database for metrics (telegraf will create it if not exists).
database = "mqtt-telegraf-db" # required
## Retention policy to write to. Empty string writes to the default rp.
retention_policy = ""
## Write consistency (clusters only), can be: "any", "one", "quorum", "all"
write_consistency = "any"
## Write timeout (for the InfluxDB client), formatted as a string.
## If not provided, will default to 5s. 0s means no timeout (not recommended).
timeout = "10s"
# username = "telegraf"
# password = "pwd"
## Set the user agent for HTTP POSTs (can be useful for log differentiation)
# user_agent = "telegraf"
## Set UDP payload size, defaults to InfluxDB UDP Client default (512 bytes)
# udp_payload = 1024
## Optional SSL Config
# ssl_ca = "/etc/telegraf/ca.pem"
# ssl_cert = "/etc/telegraf/cert.pem"
# ssl_key = "/etc/telegraf/key.pem"
## Use SSL but skip chain & host verification
# INPUT PLUGINS #
# Read metrics from MQTT topic(s)
[[inputs.mqtt_consumer]]
servers = ["localhost:1883"]
## MQTT QoS, must be 0, 1, or 2
qos = 0
## Topics to subscribe to
topics = [
"Lenze",
"LACC"
# if true, messages that can't be delivered while the subscriber is offline
# will be delivered when it comes back (such as on service restart).
# NOTE: if true, client_id MUST be set
persistent_session = false
# If empty, a random client ID will be generated.
client_id = ""
## username and password to connect MQTT server.
# password = "pwd"
data_format = "json"
