Send csv file to influxdb using node-red
I have a csv file which look like this:
Time [2:0] [2:1] [2:2] [2:3] [2:4] [2:5] [2:6] [2:7] [coil_id]
time Ziehkraft_IST Ziehkraft_IST_INT Ziehkraft_IST_LIN Drehzahl-Istwert vom Regler Strom-Istwert vom Regler ISTWERT ZIEHGESCHW.GEGLAETET ISTWERT ZIEHGESCHW.GEGLAETET Ziehkraft_IST_V coil_id
sec
14.07.2017 19:03:15.000000 303.818 0 0.760291 0.72338 144.676 0.723379 144.676 0.0303818 nan
14.07.2017 19:03:15.010000 303.818 0 0.760291 0.72338 144.676 0.723379 144.676 0.0303818 0
14.07.2017 19:03:15.020000 303.818 0 0.760291 0.72338 144.676 0.723379 144.676 0.0303818 0
14.07.2017 19:03:15.030000 303.818 0 0.760291 0.72338 144.676 0.723379 144.676 0.0303818 0
14.07.2017 19:03:15.040000 303.818 0 0.760291 0.72338 144.676 0.723379 144.676 0.0303818 0
I have created nodes in node-red to send the data in node-red which look like this:
here I am able to see the result in debug node but I am not able to write the correct json script in function node before sending to influxdb.
I use this script:
msg.payload = [
msg.payload.csv
def convertTime(s):
try:
dt = set.datetime.strptime(s, ‘%d.%m.%Y %H:%M:%S.%f’)
return dt
except:
return None
tag:“COIL_ID”
return msg;
I am new to nodered and influxdb .Please let me know(json script) that how can I send my csv file with correct timestamp and a tag key.
your efforts will be appreciated.
Interested to do similar CSV to node red to influxdb.
Did you find what was wrong?
Hello @FredCyr,
Welcome!
The easiest would be to convert the data to unix timestamp.
