Hello I am using Python Script to transfer my csv file to influxdb.
This is short discription of my file
| Time | [2:0] | [2:1] | [2:2] | [2:3] | [2:4] | [2:5] | [2:6] | [2:7] | [2:9] | [2:10] | [coil_id] |
| time | Ziehkraft_IST | Ziehkraft_IST_INT | Ziehkraft_IST_LIN | Drehzahl-Istwert vom Regler | Strom-Istwert vom Regler | ISTWERT ZIEHGESCHW.GEGLAETET | ISTWERT ZIEHGESCHW.GEGLAETET | Ziehkraft_IST_V | D_Roh | D_Fertig | coil_id |
| sec | |||||||||||
| 14.07.2017 19:03:15.000000 | 303.818 | 0 | 0.760291 | 0.72338 | 144.676 | 0.723379 | 144.676 | 0.0303818 | 345 | 310 | nan |
| 14.07.2017 19:03:15.010000 | 303.818 | 0 | 0.760291 | 0.72338 | 144.676 | 0.723379 | 144.676 | 0.0303818 | 345 | 310 | 0 |
I used this python script to export my csv to python
import pandas as pd
from influxdb import DataFrameClient
import numpy as np
def convertTime(s):
try:
dt = pd.datetime.strptime(s, ‘%d.%m.%Y %H:%M:%S.%f’)
return dt
except:
return None
df = pd.read_csv(‘one.CSV’, delimiter=’;’, skiprows=[0,2,3,4])
print(df.head())
df[“time”] = df[“time”].map(convertTime)
df = df.set_index(“time”)
print(df.head())
client = DataFrameClient(host=‘localhost’, port=8086 )
client.switch_database(‘MF’)
#client.write_points(df, ‘iba’)
nRows, nCols = df.shape
K = 1000
n0 = 0
while n0 < nRows:
n1 = min(n0 + K, nRows)
print(n0, n1)
client.write_points(df[n0:n1], ‘three’)
n0 = n1
with this script my csv was transfered to influxdb but
1 I want to transfer the data with tag = coil_id , please let me know what to write/change in the script
2 I want to add 3 other key field into the database:time_productive_id, time_id, coil_id_last
I tried with INTO clause:
SELECT last(b)/60 as “time_productive_id” INTO “MF”.“autogen”.“ziehmachine” FROM(SELECT cumulative_sum(a) as b FROM(SELECT last(“Ziehkraft_IST”)*0+1 as a FROM “MF”.“autogen”.“ziehmachine” WHERE “Lichtschranke am Hauptgetriebe (RSZ)” = true GROUP BY time(1s), *) GROUP BY *) GROUP BY *
SELECT last(b)/60 as “time_id” INTO “MF”.“autogen”.“Ziehmachine” FROM(SELECT cumulative_sum(a) as b FROM(SELECT last(“Ziehkraft_IST”)*0+1 as a FROM “MF”.“autogen”.“Ziehmachine” GROUP BY time(1s), *) GROUP BY “coil_id”) GROUP BY “coil_id”
SELECT last(“coil_id”) as “coil_id_last” INTO “MF”.“autogen”.“Ziehmachine” FROM “MF”.“autogen”.“Ziehmachine” GROUP BY *
SELECT last(b)/60 as “time_productive_id” FROM(SELECT cumulative_sum(a) as b FROM(SELECT last(“Ziehkraft_IST”)*0+1 as a FROM “MF”.“autogen”.“ziehmachine” GROUP BY time(1s), *) GROUP BY *) GROUP BY *
But these key fields are not showing in the database.
Please let me know the solution .
