Select values from more than 2 rows
I want to select values from more than 2 rows. I can select only from two rows
like r[“state”]=“KA” or r[“state”]= “AP”
Is there any function like in to select more than 2 rows like in (“AP”,“KA”,“MH”) in influx
Shouldn’t this work?
r["state"]="KA" or r["state"]= "AP" or r["state"]= "MH"
It is working fine for me. I want another method like in (“AP”,“KA”,“MH”)
I’m sorry, but I do not understand your question. Maybe you can try re-phrasing what you have tried and what does not work.
I have a flux query as below
from(bucket: “bucket1”)
|> filter(fn: (r) => r[“_measurement”] == “Measurement1”)
|> filter(fn:(r) => r[“state”] ==“AP” or r[“state”] ==“KA”)
|> filter(fn:(r) => r[“sales”] ==2000)
|> filter(fn: (r) => r[“tag”] == “Clothes” )
the above query is working fine for me. My doubt is can we write the above query in another way as below
|> filter(fn:(r) => r[“state”] in (“AP”,“KA”)
Is this is possible in influx
I believe you can query several fields using a regex. Can you try this?
  |> filter(fn: (r) => r["_field"] =~ /^(AP|KA)$/)
or perhaps
  |> filter(fn: (r) => r["_field"] =~ /^("AP"|"KA")$/)
Thanks a lot. I tried this query, it is working fine
Which expression worked?
I tried |> filter(fn: (r) => r[“_field”] =~ /^(AP|KA)$/)
