Multi select not working
When I try to select the below query
from(bucket: “bucketname”)
|> filter(fn:(r) =>r[“_measurement”] == “measurement”)
|> filter(fn: (r) => r[“column1”] == “‘value1’,‘value2’”")
|> last()
|> group()
|> keyValues(keyColumns: [“column1”])
|> drop(columns:[“_tag1”])
it is not working. Only single select of column1 is working. I have to keep either value1 or value2. Is it possible to keep more than one value
Regards
Sudheer
first, I am assuming column1 is a tag,
second, I don’t think you could do multi select like that.
I use or condition.
|> filter(fn: (r) => r["name"] == "name1" or r["name"] == "name2" or r["name"] == "name3" )
@AVVS_Sudheer I think you are not understanding the basic concepts of InfluxDB, I mean that not wrong everyone starts not knowing something, but you should take a look a t the documentation and examples to start understanding the basics first.
You can use regex:
|> filter(fn: (r) => r[“column1”] =~ /value1|value2/)
|> last()
|> group()
Now it is working fine. I have used regex.
Regards
Sudheer
