hi
i want to generate a report in grafana but i dont know how can i do it
Hi @nadia,
With such little detail, there is simply no way to provide any sort of meaningful answer to this question. I would encourage you to please provide as much detail – including examples of what you have tried, etc. – and details about exactly what you’re trying to achieve in roder to allow someone to assist you.
This question is simply too broad and open ended to be answerable.
Best regards,
dg
I work on grafana and influxdb and I want to generate reports, first I followed the steps of this document GitHub - IzakMarais/reporter: Service that generates a PDF report from a Grafana dashboard, but the reports are not yet generated, I do not know if I have to install something else by the way i’m using the latest version of grafana
this is what I get when I tape report
This is really a Grafana question and not an Influx question. As I’m not a Grafana expert, I am unable to answer. Maybe another user here is a Grafana expert, or you could try the Grafana user communities.
Best regards,
dg
