I have two instances of Influxdb OSS - at home on RPI and a new one on AWS cloud. I wanted to replicate data from home influx to the AWS cloud. However, the status data does not flow and the status code after entering “influx replication list” has no sign.
Please help.
Hi @wasik10,
Can you show us the commands you have run to create the replication, please? Please also note this does not replicate current data but any new inserts being added into the original bucket. You should be able to also see the last status code when using influx replication list
hello @Jay_Clifford , thank You for your interest
Hi @wasik10,
can you try adding the full URL path?
Here is my setup:
0997e8339fd89000 cloud cbd6ccb935bfd571 https://us-east-1-1.aws.cloud2.influxdata.com 05ea551cd21fb6e4 false
I belive you might be missing the https:// I would also try running the command with and without the allow insecure tls to see if this makes a difference.
