We are trying to use Telegraf to scrape the Redis /metrics page which is Prom format and having an error. The redis domains that are standalone instances work fine but the ones deployed as a cluster we see
a field for bdb_up twice in the output page which is causing Telegraf to error with :
error Unable to gather {“log_id”: “VXVSsW000”, “service”: “scraper”, “scraper-name”: “Redis”, “error”: “reading text format failed: text format parsing error in line 2546: second TYPE line for metric name "bdb_up", or TYPE reported after samples”}
**Output from /metrics HTTP Exporter page shows 2 bdb_up types as :
I think this is expected as the prometheus spec itself says:
Only one TYPE line may exist for a given metric name.
Telegraf has two different prometehus parsers, which can be toggled with the metric_version = [1|2] config option. Both parsers use the upstream prometheus parser, but produce a different format of metrics. However, given the following metrics file, both will fail with the same error:
# HELP bdb_up
# TYPE bdb_up gauge
bdb_up{bdb="4",cluster="redis.domain",status="active"} 1.0
bdb_up{bdb="3",cluster="redis.domain",status="active"} 1.0
bdb_up{bdb="17",cluster="redis.domain",status="active"} 1.0
bdb_up{bdb="8",cluster="redis.domain",status="active"} 1.0
# HELP bdb_up
# TYPE bdb_up gauge
bdb_up{bdb="111",cluster="redis.domain",crdt_guid="42439090",crdt_replica_id="2",status="active"} 1.0
bdb_up{bdb="160",cluster="redis.domain",crdt_guid="b518589d",crdt_replica_id="2",status="active"} 1.0
bdb_up{bdb="129",cluster="redis.domain",crdt_guid="e35d7e35",crdt_replica_id="2",status="active"} 1.0
The error:
2023-11-27T21:32:02Z E! [inputs.prometheus] Error in plugin: error reading metrics for "http://localhost:8000/metrics2": reading text format failed: text format parsing error in line 9: second TYPE line for metric name "bdb_up", or TYPE reported after samples
Looking around I see a number of issue reports where users file issues with the reporter to not duplicate the type comments:
The Telegraf input config is a basic Prometheus set to v2. Also for context we setup a demo Prometheus server to test if it works there and it does. They must be ignoring that openmetric standard? We engaged entry support for Redis and they were of no help stating they dont provide that support even though they are bunding the prometheus exporter with the product these days.
All of that said I wasnt sure if there was a workaround using a pre-processor / regex to relabel that metric if it contains the “crdt_guid” field to something like bdb_up_crdt ?
That is unfortunate, is the repo that is producing this public or on github? Might consider filing an issue if it is.
Unfortunately, no, any of our processors happen after the input, and the error itself is occurring from prometheus’ library during parsing. They would have to expose something that would let us ignore this part of the spec.
