The Kapacitor Getting Started guide has a “real world” example that alerts on a deviation from a 95% percentlie of a cpu metric. I’m wondering how this example can be replicated with Chronograf? This is the relevant TICK script for reference:
stream
|from()
.measurement(‘cpu’)
// create a new field called ‘used’ which inverts the idle cpu.
|eval(lambda: 100.0 - “usage_idle”)
.as(‘used’)
|groupBy(‘service’, ‘datacenter’)
|window()
.period(1m)
.every(1m)
// calculate the 95th percentile of the used cpu.
|percentile(‘used’, 95.0)
|eval(lambda: sigma(“percentile”))
.as(‘sigma’)
.keep(‘percentile’, ‘sigma’)
|alert()
.id(’{{ .Name }}/{{ index .Tags “service” }}/{{ index .Tags “datacenter”}}’)
.message(’{{ .ID }} is {{ .Level }} cpu-95th:{{ index .Fields “percentile” }}’)
// Compare values to running mean and standard deviation
.warn(lambda: “sigma” > 2.5)
.crit(lambda: “sigma” > 3.0)
.log(’/tmp/alerts.log’)
// Post data to custom endpoint
.post('https://alerthandler.example.com')
// Execute custom alert handler script
.exec('/bin/custom_alert_handler.sh')
// Send alerts to slack
.slack()
.channel('#alerts')
// Sends alerts to PagerDuty
.pagerDuty()
// Send alerts to VictorOps
.victorOps()
.routingKey('team_rocket')
In particular I’m interested in how to implement the eval(), the percentile(), and the alert().id() in Chronograf. I’m also wondering if templates are possible through Chronograf.
Thanks in advance.
