Hi ,
I am planning to create an alert when
(1h_average - 7d_min) is 3 times higher than (7d_average – 7d_min)
I am using python script to write directly into the influxdb. Is it possible to use Kapacitor to create alerts like this ? with out the use of the telegraf.
Hello @BhanuKiran,
Yes absolutely. I recently did something similar and then I created the Kapacitor alert through the TICK script builder in Chronograf.
Hi @Anaisdg ,
I went through the documentation and it mentioned that most common alerts ( Threshold/static ceiling /Relative/Deadman switches etc) can be done through chronograph and more refined alerts should be declared directly in Kapacitor.
I don’t see how to create an alert that look like this
(1h_average - 7d_min) is 3 times higher than (7d_average – 7d_min) Using Tick script builder in chronograph. Can u point to more specific resource ?
Yes, I just point users to the Tick Script builder first as a starting point. I would look at some of these examples.
