Image 1: initially all the data shows on the dashboard (12/08/2022 12:54)
Image 2: after a while, all widgets crash (within minutes) (12/08/2022 12:55)
Hi folks,
Here is some background about my setup:
There is an MQTT network sending IoT data to a raspberry Pi
raspberry pi runs a python script to upload data to influxdb (in real time)
currently uploading data every 3s
each upload is a list of lines, each line being measurement/tag_set/field_set/timestamp format
upload method is by using python paho mqtt, and line protocol
Essentially, this setup now works, data is at the database, and it is being visualized in a dashboard. However, when refreshing the dashboard at a quick rate (e.g. refreshing every 1 second), it works for 5 minutes and then shows these errors. When I go inside a widget, I cannot submit a new query and cannot see any raw data anymore… It’s like a timerangestart and timerangestop data goes missing…
The dashboard works once again after the page is refreshed. So I am really confused on why that happens, what caused it, and how to fix it. I found only one similar error on this forum, but the one I am currently facing is time - based! This issue only occurs after a few minutes of working successfully!
Note: I now realize that refreshing every 1s gives this error in a couple of minutes, refreshing every 5s gives the error within ~20 minutes, refreshing every 10s gives the error within less than an hour… It’s almost as if some limit is reached, and refreshing the page is the fix. An odd problem!
Hi @scott , thanks for the reply. Yeah, it seems like it
All these queries used for dashboard are pre-defined, so I did not mess up any of the settings. An odd thing to note is:
The dashboard crashes
I go to configure the widget
I go to script editor
When I click submit, I get that error message
So it seems like the actual piece of data just disappears or something like that
You should submit a bug report on the InfluxDB repo with all of these details. That will allow to InfluxData engineers to troubleshoot and triage what exactly is going on.
