Hi jpowers,
debug on with telegraf, check telegraf log,found some things.
contents from telegraf log:
2023-07-07T18:03:01+08:00 D! [parsers.grok::tail] Grok no match found for: "[2023:07:07 18:02:58][DEBUG]出口通道号16,发送系统时间2023年07月07日"
2023-07-07T18:03:01+08:00 D! [parsers.grok::tail] Grok no match found for: "[2023:07:07 18:02:58][ERROR]通道号[2],IP[172.16.60.11]登陆成功后不能通讯"
2023-07-07T18:03:06+08:00 D! [outputs.influxdb_v2] Wrote batch of 4 metrics in 1.0002ms
2023-07-07T18:03:06+08:00 D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2023-07-07T18:03:16+08:00 D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2023-07-07T18:03:26+08:00 D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2023-07-07T18:03:36+08:00 D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2023-07-07T18:03:46+08:00 D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2023-07-07T18:03:56+08:00 D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
content from handling log (source log)
[2023:07:07 18:02:58][INFO]出场场上报请求信息{"ParkCode":"510105037","VehicleNo":"GJ9L91","EventTime":"2023-07-07 18:02:20","StartTime":"2023-07-07 12:59:39","PaymentMoney":14.0,"TotalMoney":14.0,"DeductionMoney":0.0,"IsAutoPay":false,"CouponName":"","CouponMoney":0.0,"OperateCount":1738,"Qn":"2307071802200000008","BookingCode":"","ConsumeType":1,"PayType":2,"ChannelNo":8,"ChannelName":"3号楼出口2","CarImageID":"2307071802200000008","ISETCPay":false,"ETCPaymentMoney":0.0}
[2023:07:07 18:02:58][ERROR]通道号[4],IP[172.16.60.13]登陆成功后不能通讯
[2023:07:07 18:02:58][ERROR]通道号[1],IP[172.16.60.10]一体机重连不能通讯
[2023:07:07 18:02:58][ERROR]通道号[13],IP[10.18.212.12]一体机重连不能通讯
[2023:07:07 18:02:58][ERROR]通道号[11],IP[10.18.212.10]一体机重连不能通讯
[2023:07:07 18:02:58][ERROR]通道号[3],IP[172.16.60.12]一体机重连不能通讯
[2023:07:07 18:03:00][ERROR]通道号[2],IP[172.16.60.11]登陆成功后不能通讯
question: from telegraf log, can saw last telegraf grok’s information [2023:07:07 18:02:58][ERROR]通道号[2],IP[172.16.60.11]登陆成功后不能通讯 at 18:03:06+08:00, and then telegraf did not grok new message from source log.
check source log, can saw new message still coming. why?
