Query throws RPAREN, got EOF error
I try to query my influxdb2 from a python script using influxdb_client.
If I use this query I do get data:
query =  'from(bucket: "telegraf")\
|> range(start: -1m)'
however, if I use this query :
|> range(start: -1m)\
|> filter(fn:(r) => r._measurement == “diskio")'
I get this error:
Reason: Bad Request
HTTP response headers: HTTPHeaderDict({'Content-Type': 'application/json; charset=utf-8', 'Date': 'Wed, 17 Mar 2021 14:47:06 GMT', 'Vary': 'Accept-Encoding', 'X-Platform-Error-Code': 'invalid', 'Content-Length': '96'})
HTTP response body: b'{"code":"invalid","message":"compilation failed: error at @1:48-1:94: expected RPAREN, got EOF"}'
Does anyone know what I do wrong?
Hi @kkoen,
you have to add the ' also at the end of line.
Correct query looks like:
query = 'from(bucket: "telegraf")' \
        '|> range(start: -1m)'
You could also use following syntax:
query = '''
from(bucket:"my-bucket")
        |> range(start: 0, stop: now())
        |> filter(fn: (r) => r._measurement == "h2o_feet")
Regards
thank you @bednar , I have tried both methods but without luck. As soon as I add the 3rd line I get the error. This is my last try:
    query = '''
        |> range(start: -1m)
        |> filter(fn:(r) => r._field == "read_bytes" )
The following examples has correct syntax:
Thank you. I have good results now. Syntax was fine, but adding a yield statement made the difference:
query = 'from(bucket:"telegraf")'\
        ' |> range(start: -1m)'\
        ' |> filter(fn: (r) => r["_measurement"] == "diskio")'\
        ' |> filter(fn: (r) => r["_field"] == "read_bytes")'\
        ' |> yield(name: "mean")'
This gives me the expected data.
Instead of hard-coding bucket value as “telegraf”, how to pass it as variable ? I tried multiple ways, but all are giving error. Thank you.
You can achieve it by using f-string in python, but you need to be careful with quotes.
refer solution and it will definitely works for you.
var_name = 'test_db'
query = 'from(bucket:{var_name})\
        |> range(start: -1m)\
        |> filter(fn: (r) => r["_measurement"] == "diskio")\
        |> filter(fn: (r) => r["_field"] == "read_bytes")\
OR
query = 'from(bucket: "' + var_name + '")\
        |> range(start: -1m)\
