InfluxDB v2.0.0-alpha Query API via Postman
Hi
I am trying to use Postman to test queries on v2.0.0-alpha. I cannot find any examples using the JSON body with the “query” key. Documentation says “query”: “string”. I have tried the following as the JSON body:
“query”: “from(bucket: ‘datasourceId’) |> range(start: -1h, stop: -1m) |> filter(fn: ® => r._measurement == ‘m’) |> filter(fn: ® => r._field == ‘q’) |> filter(fn: ® => r.t== ‘name001’)”
But get the following response:
“code”: “invalid”,
“message”: “failed to execute query against proxy service”,
“op”: “http/handlePostQuery”,
“error”: {
“code”: “invalid”,
“message”: “compilation failed: loc 1:6-1:27: invalid expression @1:27-1:28: '”
donot use json as content type, just raw test. Like this:
Hi @kilik52, thanks for your response.
However, even when using the “Text” body of:
from(bucket: “datasourceId”) |> range(start: -10h)
I am getting the following error response:
“code”: “invalid”,
“message”: “failed to decode request body”,
“error”: “invalid character ‘r’ in literal false (expecting ‘a’)”
I am not sure which character ‘r’ is causing the issue?
Hope you can assist.
u may upload some screenshot. let me see ur headers and body
Thanks @kilik52. See my screenshots. The only header I am adding is the Token.
try add another header:
Content-Type: application/vnd.flux
Hi, I’m trying to make API call to query data from my Influxdb 2.0 v2.0.0-alpha db using Postman but I cant receive data in json format.
Is it there some parameter that I miss or do I have to use Flux Json package in some way?
Thanks in advance
Flux results are returned in annotated CSV only. There isn’t an option for JSON output.
