Issues on creating a check via the InfluxDB v2 API
I am currently working on my bachelor thesis and for this I am working with InfluxDB.
I am trying to create a Check in InfluxDB with the v2 API via Postman and get this Response:
“unable to detect the check type from json”
This is my request body:
    "name": "<name>",
    "ownerID": "<owner id>",
    "orgID": "<org id>",
    "query": {
        "text": "from(bucket: \"<bucket name>\")\n  |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\n  |> filter(fn: (r) => r[\"_measurement\"] == \"<measurement name>\")\n  |> filter(fn: (r) => r[\"_field\"] == \"<field name>\"),
        "editMode": "builder",
        "name": "<query name>",
        "builderConfig": {
            "buckets": [
                "<bucket name>"
            "tags": [
                    "key": "_measurement",
                    "values": [
                        "<measurement name>"
                    "aggregateFunctionType": "filter"
                    "key": "_field",
                    "values": [
                        "<field name>"
            "functions": [
                    "name": "mean"
            "aggregateWindow": {
                "period": "1m",
                "fillValues": false
    "statusMessageTemplate": "Check: ${ r._check_name } is: ${ r._level }",
    "every": "5s",
    "offset": "1s",
    "thresholds": [
            "allValues": false,
            "level": "CRIT",
            "min": 0.2,
            "max": 1.1,
            "within": true,
            "type": "range"
    "type": "threshold",
    "status": "active"
I don’t understand the error response. As written in my request body I set the type to “threshold”.
Did anybody else encountered this problem or could help me in any way?
Best regards,
Vinzenz
Hello @vinnivitz,
This post could be of value to you:
Of course you’ll want to replace it with a threshold check instead.
Like:
  "name": "Test Check2",
  "orgID": "0437f6d51b579000",
  "query": {
    "text": "from(bucket:\"telegraf\") |> range(start:-5h) |> filter(fn:(r) => r._measurement == \"cpu\")"},
  "name": "check2",
  "status": "active",
  "description": "this is a check2",
  "every": "1m",
  "offset": "10s",
  "statusMessageTemplate": "Critical State"
  "thresholds": [
"level": "UNKNOWN",
"allValues": true,
"type": "greater",
"value": 0
I hope that helps. I haven’t tested it though so please let me know if you’re still having problems.
Thank you so much for the quick response! It solved my problem! And sorry for the late answer.
Unfortunately I am facing a new issue when creating a notification rule.
    "endpointID": "<endpointID>",
    "name": "<name>",
    "orgID": "<orgID>",
    "status": "active",
    "type": "http",
    "statusRules": [
            "currentLevel": "CRIT"
And the response is an internal error:
    "code": "internal error",
    "message": "a panic has occurred: /api/v2/notificationRules: runtime error: invalid memory address or nil pointer dereference"
The output from the database is the following.
2021-09-20T13:53:47.625052Z	error	a panic has occurred	{"log_id": "0WhsaOQG000", "handler": "panic", "error": "/api/v2/notificationRules: runtime error: invalid memory address or nil pointer dereference"}
goroutine 2932 [running]:
runtime/debug.Stack(0xc0029f0ea0, 0xc001c34802, 0x56223a7a9387)
	runtime/debug/stack.go:24 +0x9f
github.com/influxdata/influxdb/v2/http.baseHandler.panic(0x56223c348f58, 0x56223ba80990, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00, 0x56223bf67580, 0x56223d2723d0)
	github.com/influxdata/influxdb/v2/http/router.go:96 +0x21d
github.com/influxdata/httprouter.(*Router).recv(0xc002dbbdd0, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
	github.com/influxdata/httprouter@v1.3.1-0.20191122104820-ee83e2772f69/router.go:361 +0x7e
panic(0x56223bf67580, 0x56223d2723d0)
	runtime/panic.go:965 +0x1b9
github.com/influxdata/influxdb/v2/notification/rule.increaseDur(0x0, 0x10)
	github.com/influxdata/influxdb/v2/notification/rule/rule.go:256 +0x40
github.com/influxdata/influxdb/v2/notification/rule.(*Base).generateFluxASTStatuses(0xc0023977a0, 0x56223c3b0808, 0xc00250b000)
	github.com/influxdata/influxdb/v2/notification/rule/rule.go:294 +0x49
github.com/influxdata/influxdb/v2/notification/rule.(*HTTP).generateFluxASTBody(0xc0023977a0, 0xc00250b000, 0xc0023bf740, 0x4, 0x4)
	github.com/influxdata/influxdb/v2/notification/rule/http.go:62 +0x251
github.com/influxdata/influxdb/v2/notification/rule.(*HTTP).GenerateFluxAST(0xc0023977a0, 0xc00250b000, 0x56223c388ce0, 0xc002cec570, 0x82cdc785abb1000)
	github.com/influxdata/influxdb/v2/notification/rule/http.go:36 +0x85
github.com/influxdata/influxdb/v2/notification/rule.(*HTTP).GenerateFlux(0xc0023977a0, 0x56223c3b0808, 0xc00250b000, 0x82cdc785abb1000, 0x56223c3b0808, 0xc00250b000, 0x0)
	github.com/influxdata/influxdb/v2/notification/rule/http.go:24 +0x59
github.com/influxdata/influxdb/v2/notification/rule/service.(*RuleService).createNotificationTask(0xc000bdd960, 0x56223c388ce0, 0xc002cec570, 0x56223c3b34f8, 0xc0023977a0, 0xc002ce4e18, 0x6, 0x2a, 0x56223bfedc01, 0x24)
	github.com/influxdata/influxdb/v2/notification/rule/service/service.go:160 +0xd0
github.com/influxdata/influxdb/v2/notification/rule/service.(*RuleService).CreateNotificationRule(0xc000bdd960, 0x56223c388ce0, 0xc002cec570, 0x56223c3b34f8, 0xc0023977a0, 0xc002ce4e18, 0x6, 0x82bd4a44b1b1000, 0x11, 0x0)
	github.com/influxdata/influxdb/v2/notification/rule/service/service.go:119 +0x1bd
github.com/influxdata/influxdb/v2/task/backend/middleware.(*CoordinatingNotificationRuleStore).CreateNotificationRule(0xc0007d6840, 0x56223c388ce0, 0xc002cec570, 0x56223c3b34f8, 0xc0023977a0, 0xc002ce4e18, 0x6, 0x82bd4a44b1b1000, 0x5, 0x56223a79f33c)
	github.com/influxdata/influxdb/v2/task/backend/middleware/notification_middleware.go:37 +0xa5
github.com/influxdata/influxdb/v2/authorizer.(*NotificationRuleStore).CreateNotificationRule(0xc000637410, 0x56223c388ce0, 0xc002cec570, 0x56223c3b34f8, 0xc0023977a0, 0xc002ce4e18, 0x6, 0x82bd4a44b1b1000, 0x0, 0x0)
	github.com/influxdata/influxdb/v2/authorizer/notification_rule.go:56 +0x11a
github.com/influxdata/influxdb/v2/http.(*NotificationRuleHandler).handlePostNotificationRule(0xc002dbbe60, 0x56223c3766e8, 0xc0023bf340, 0xc00250af00)
	github.com/influxdata/influxdb/v2/http/notification_rule.go:588 +0x42a
net/http.HandlerFunc.ServeHTTP(0xc002dce040, 0x56223c3766e8, 0xc0023bf340, 0xc00250af00)
	net/http/server.go:2069 +0x46
github.com/influxdata/influxdb/v2/http.(*proxyHandler).ServeHTTP(0xc000dc1960, 0x56223c3766e8, 0xc0023bf340, 0xc00250af00)
	github.com/influxdata/influxdb/v2/http/proxy_handler.go:33 +0x9d
github.com/influxdata/httprouter.(*Router).Handler.func1(0x56223c3766e8, 0xc0023bf340, 0xc00250af00, 0x0, 0x0, 0x0)
	github.com/influxdata/httprouter@v1.3.1-0.20191122104820-ee83e2772f69/router.go:325 +0x1e7
github.com/influxdata/httprouter.(*Router).ServeHTTP(0xc002dbbdd0, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
	github.com/influxdata/httprouter@v1.3.1-0.20191122104820-ee83e2772f69/router.go:453 +0xa9b
github.com/go-chi/chi.(*Mux).Mount.func1(0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
	github.com/go-chi/chi@v4.1.0+incompatible/mux.go:298 +0x122
net/http.HandlerFunc.ServeHTTP(0xc000dc1ae0, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
github.com/go-chi/chi.(*Mux).routeHTTP(0xc002dabe00, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
	github.com/go-chi/chi@v4.1.0+incompatible/mux.go:431 +0x28b
net/http.HandlerFunc.ServeHTTP(0xc002da1980, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
github.com/influxdata/influxdb/v2/kit/transport/http.SetCORS.func1(0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
	github.com/influxdata/influxdb/v2/kit/transport/http/middleware.go:35 +0xcd
net/http.HandlerFunc.ServeHTTP(0xc0009fc840, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
github.com/go-chi/chi/middleware.StripSlashes.func1(0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
	github.com/go-chi/chi@v4.1.0+incompatible/middleware/strip.go:25 +0xee
net/http.HandlerFunc.ServeHTTP(0xc0009fc858, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
github.com/influxdata/influxdb/v2/kit/transport/http.SkipOptions.func1(0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
	github.com/influxdata/influxdb/v2/kit/transport/http/middleware.go:73 +0xba
net/http.HandlerFunc.ServeHTTP(0xc0009fc900, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
github.com/influxdata/influxdb/v2/http.panicMW.func1.1(0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
	github.com/influxdata/influxdb/v2/http/router.go:126 +0x93
net/http.HandlerFunc.ServeHTTP(0xc000dc13c0, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
github.com/go-chi/chi.(*Mux).ServeHTTP(0xc002dabe00, 0x56223c3766e8, 0xc0023bf340, 0xc00250ae00)
	github.com/go-chi/chi@v4.1.0+incompatible/mux.go:70 +0x50c
github.com/influxdata/influxdb/v2/kit/feature.(*Handler).ServeHTTP(0xc002df5f80, 0x56223c3766e8, 0xc0023bf340, 0xc00250ad00)
	github.com/influxdata/influxdb/v2/kit/feature/middleware.go:43 +0x2a2
github.com/influxdata/influxdb/v2/http.(*AuthenticationHandler).ServeHTTP(0xc0005e0380, 0x56223c3766e8, 0xc0023bf340, 0xc00250ac00)
	github.com/influxdata/influxdb/v2/http/authentication_middleware.go:125 +0x2d2
github.com/influxdata/influxdb/v2/kit/transport/http.SetCORS.func1(0x56223c3766e8, 0xc0023bf340, 0xc00250ac00)
net/http.HandlerFunc.ServeHTTP(0xc000e0cd38, 0x56223c3766e8, 0xc0023bf340, 0xc00250ac00)
github.com/influxdata/influxdb/v2/kit/transport/http.SkipOptions.func1(0x56223c3766e8, 0xc0023bf340, 0xc00250ac00)
net/http.HandlerFunc.ServeHTTP(0xc000e0cd50, 0x56223c3766e8, 0xc0023bf340, 0xc00250ac00)
github.com/influxdata/influxdb/v2/http.(*PlatformHandler).ServeHTTP(0xc000959d10, 0x56223c3766e8, 0xc0023bf340, 0xc00250ac00)
	github.com/influxdata/influxdb/v2/http/platform_handler.go:78 +0x154
github.com/go-chi/chi.(*Mux).Mount.func1(0x56223c3766e8, 0xc0023bf340, 0xc00250ac00)
net/http.HandlerFunc.ServeHTTP(0xc00061ec00, 0x56223c3766e8, 0xc0023bf340, 0xc00250ac00)
github.com/influxdata/influxdb/v2/kit/transport/http.Metrics.func1.1(0x56223c37cad8, 0xc002397500, 0xc00250ac00)
	github.com/influxdata/influxdb/v2/kit/transport/http/middleware.go:58 +0x191
net/http.HandlerFunc.ServeHTTP(0xc002dff380, 0x56223c37cad8, 0xc002397500, 0xc00250ac00)
github.com/influxdata/influxdb/v2/kit/transport/http.Trace.func1.1(0x56223c37cad8, 0xc002397500, 0xc00250ac00)
	github.com/influxdata/influxdb/v2/kit/transport/http/middleware.go:98 +0x38f
net/http.HandlerFunc.ServeHTTP(0xc000ed79b0, 0x56223c37cad8, 0xc002397500, 0xc00250ab00)
github.com/go-chi/chi.(*ChainHandler).ServeHTTP(0xc002dff3c0, 0x56223c37cad8, 0xc002397500, 0xc00250ab00)
	github.com/go-chi/chi@v4.1.0+incompatible/chain.go:31 +0x54
github.com/go-chi/chi.(*Mux).routeHTTP(0xc002dfa420, 0x56223c37cad8, 0xc002397500, 0xc00250ab00)
net/http.HandlerFunc.ServeHTTP(0xc002dcebd0, 0x56223c37cad8, 0xc002397500, 0xc00250ab00)
github.com/go-chi/chi.(*Mux).ServeHTTP(0xc002dfa420, 0x56223c37cad8, 0xc002397500, 0xc0026f1e00)
	github.com/go-chi/chi@v4.1.0+incompatible/mux.go:86 +0x2d1
github.com/influxdata/influxdb/v2/http.(*Handler).ServeHTTP(0xc002df80c0, 0x56223c37cad8, 0xc002397500, 0xc0026f1e00)
	github.com/influxdata/influxdb/v2/http/handler.go:145 +0x57
net/http.serverHandler.ServeHTTP(0xc0009aa620, 0x56223c37cad8, 0xc002397500, 0xc0026f1e00)
	net/http/server.go:2887 +0xa5
net/http.(*conn).serve(0xc0028f4500, 0x56223c388ce0, 0xc002d200c0)
	net/http/server.go:1952 +0x8cd
created by net/http.(*Server).Serve
	net/http/server.go:3013 +0x3ad
I am using version 2.0.7
Do you have any idea what I am doing wrong or is a known issue because I found this type of error also in other relations but non of the provided solution helped my out…
Best,
Vinzenz
Ok. I solved the problem. the property every is required for creating a notification rule. In the docs it is not marked as required. Maybe you could updated this to avoid further problems.
Thanks again for your help!
Best,
Vinzenz
@vinnivitz,
Thanks for sharing your solution!
