Hello @ThePeltonian,
This worked for me.
from(bucket: "noaa")
|> filter(fn: (r) => r["_measurement"] == "h2o_feet" or r["_measurement"] == "average_temperature")
|> filter(fn: (r) => r["_field"] == "degrees" or r["_field"] == "water_level")
|> filter(fn: (r) => r["location"] == "coyote_creek")
|> group()
|> schema.fieldsAsCols()
|> filter(fn: (r) => r.water_level != 7.5)
|> yield(name: "mean")
Using the noaa sample dataset
please let me know if it works for you.
Hi @Anaisdg
Thankyou for the reply, gave me something else to go at, I kept getting errors when trying the above but I have kinda got it to work and pull back nearly how I want it but with a few issues
from(bucket: "telegraf") |> range(start: v.timeRangeStart, stop: v.timeRangeStop) |> filter(fn: (r) => r["_measurement"] == "win_services") |> filter(fn: (r) => r["_field"] == "state" or r["_field"] == "startup_mode") |> filter(fn: (r) => r["service_name"] == "PROCESS FRAMEWORK") |> filter(fn: (r) => r["host"] =~ "Server1") |> pivot( rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value" ) |> filter(fn: (r) => r.startup_mode != 4) |> drop(columns: ["startup_mode"]) |> yield(name: "last")
When the results come back I only have state = 4 showing on the legend, how can i get it to show the full details?
@ThePeltonian,
Hmm I’m not sure what are the full details you are expecting? Why did you end up dropping the startup_mode?
Hi @Anaisdg,
The result I want to show in the results table & legend is state to show that it is in state 4 (running) as will be alerting on if this drops below 4 as this will be not running - the issue we have is that sometimes there are services installed and in stopped state - but the startup_mode = 4 (disabled).
Before adding the pivot the results would pull back the full data for state including service name, host etc.
