I’m writing my first python batch UDF for kapacitor that uses the Facebook Prophet model to forecast future cpu usage on a group of servers. The goal is to create graphs with these metrics that show our prophet prediction vs current usage.
OS: CentOS Linux release 7.2.1511
Kapacitor Version: Kapacitor OSS 1.5.0 (git: HEAD 4f10efc41b4dcac070495cf95ba2c41cfcc2aa3a)
Python Version: Python 2.7.5, protobuf (3.6.1), kapacitor-udf (1.0.0)
TICKscript:
dbrp "telegraf"."autogen"
var data = batch
|query('''
SELECT mean("usage_user") as value
FROM "telegraf"."autogen"."cpu"
WHERE "role"='hdap_api_ui'
.groupBy(time(1h))
.offset(5m)
.align()
.period(30d)
.every(1m)
data
@prophet()
.periods(24)
.field('value')
.freq('H')
.changepoint_prior_scale(0.001)
.include_history(FALSE)
|influxDBOut()
.database('kapacitor')
.measurement('fbprophet_hdap_api_ui')
UDF:
import sys
import json
from kapacitor.udf.agent import Agent, Handler
from kapacitor.udf import udf_pb2
import warnings
warnings.filterwarnings("ignore", message="numpy.dtype size changed")
warnings.filterwarnings("ignore", message="numpy.ufunc size changed")
warnings.filterwarnings('ignore', message="Conversion of the second argument")
from fbprophet import Prophet
import pandas as pd
import numpy as np
import logging
logging.basicConfig(level=logging.DEBUG, format='%(asctime)s %(levelname)s:%(name)s: %(message)s')
logger = logging.getLogger()
import pprint
class ProphetHandler(Handler):
class state(object):
def __init__(self):
self._entries = []
def reset(self):
self._entries = []
def update(self, value, ds):
self._entries.append((value, ds))
def get_entries(self):
return self._entries
def __init__(self, agent):
self._agent = agent
self._points = []
self._field = None
self._periods = 0
self._freq = None
self._changepoint_prior_scale = None
self._growth = None
self._cap = None
self._include_history = None
self._state = ProphetHandler.state()
self._begin_response = None
def info(self):
response = udf_pb2.Response()
response.info.wants = udf_pb2.BATCH
response.info.provides = udf_pb2.BATCH
response.info.options['field'].valueTypes.append(udf_pb2.STRING)
response.info.options['periods'].valueTypes.append(udf_pb2.INT)
response.info.options['freq'].valueTypes.append(udf_pb2.STRING)
response.info.options['changepoint_prior_scale'].valueTypes.append(udf_pb2.DOUBLE)
response.info.options['growth'].valueTypes.append(udf_pb2.STRING)
response.info.options['cap'].valueTypes.append(udf_pb2.DOUBLE)
response.info.options['include_history'].valueTypes.append(udf_pb2.BOOL)
return response
def init(self, init_req):
success = True
msg = ''
for opt in init_req.options:
if opt.name == 'field':
self._field = opt.values[0].stringValue
elif opt.name == 'periods':
self._periods = opt.values[0].intValue
elif opt.name == 'cap':
self._cap = opt.values[0].doubleValue
elif opt.name == 'growth':
self._growth = opt.values[0].stringValue
elif opt.name == 'freq':
self._freq = opt.values[0].stringValue
elif opt.name == 'changepoint_prior_scale':
self._changepoint_prior_scale = opt.values[0].doubleValue
elif opt.name == 'include_history':
self._include_history = opt.values[0].boolValue
if self._field is None:
success = False
msg += ' must supply field'
if self._periods <= 0:
success = False
msg += ' periods must be > to 0'
response.init.success = success
response.init.error = msg[1:]
logger.info('init %s', msg)
return response
def snapshot(self):
response.snapshot.snapshot = ''
return response
def restore(self, restore_req):
response.restore.success = False
response.restore.error = 'not implemented'
return response
def begin_batch(self, begin_req):
self._state.reset()
response.begin.CopyFrom(begin_req)
self._begin_response = response
logger.info('begin batch')
def point(self, point):
value = point.fieldsDouble[self._field]
self._state.update(value, point.time)
def forecast(self):
entries = self._state.get_entries()
ds = []
y = []
for a, b in entries:
ds.append(b)
y.append(a)
d = {'y': y, 'ds': ds}
#d['y'] = np.log(d['y'])
df = pd.DataFrame(d)
if self._cap is not None:
df['cap'] = self._cap
m = None
if self._changepoint_prior_scale is not None and self._growth is not None:
m = Prophet(changepoint_prior_scale=self._changepoint_prior_scale, growth=self._growth)
elif self._changepoint_prior_scale is not None:
m = Prophet(changepoint_prior_scale=self._changepoint_prior_scale)
elif self._growth is not None:
m = Prophet(growth=self._growth)
else:
m = Prophet()
logger.info('fit model')
m.fit(df)
future = None
if self._freq is not None and self._include_history is not None:
future = m.make_future_dataframe(periods=self._periods, include_history=self._include_history, freq=self._freq)
elif self._freq is not None:
future = m.make_future_dataframe(periods=self._periods, freq=self._freq)
elif self._include_history is not None:
future = m.make_future_dataframe(periods=self._periods, include_history=self._include_history)
else:
future = m.make_future_dataframe(periods=self._periods)
forecast = m.predict(future)
logger.info('forecasted')
return forecast
def end_batch(self, end_req):
forecast = self.forecast()
self._begin_response.begin.size = len(forecast)
self._agent.write_response(self._begin_response)
for index, rows in forecast.iterrows():
point = {'yhat': rows['yhat'], 'yhat_lower': rows['yhat_lower'], 'yhat_upper': rows['yhat_upper']}
response.point.time = int(rows['ds'].timestamp()) * 1000000000
response.point.fieldsDouble['yhat'] = (rows['yhat'])
response.point.fieldsDouble['yhat_upper'] = (rows['yhat_upper'])
response.point.fieldsDouble['yhat_lower'] = (rows['yhat_lower'])
response.point.CopyFrom(response.point)
self._agent.write_response(response)
logger.info(response.point)
response.end.CopyFrom(end_req)
logger.info('ending batch')
if __name__ == '__main__':
a = Agent()
h = ProphetHandler(a)
a.handler = h
logger.info("Starting Prophet Agent")
a.start()
a.wait()
logger.info("Prophet Agent finished")
Show Task:
Error: prophet2: read error: proto: can't skip unknown wire type 6 for agent.Response
Template:
Type: batch
Status: enabled
Executing: false
Created: 22 Aug 18 16:57 UTC
Modified: 23 Aug 18 18:55 UTC
LastEnabled: 23 Aug 18 18:55 UTC
Databases Retention Policies: ["telegraf"."autogen"]
TICKscript:
var data = batch
|query('''
.groupBy(time(1h))
.offset(5m)
.align()
.period(30d)
.every(1m)
data
@prophet()
.periods(24)
.field('value')
.freq('H')
|influxDBOut()
DOT:
digraph prophet {
query1 -> prophet2;
prophet2 -> influxdb_out3;
Time to play!
