Hi Nice people
I come back with my questions about ARIMA kapacitor UDF.
Now I have been to log the forecast values in kapacitor log as you see:
ts=2018-09-28T10:01:00.114+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 10:01:00,114 INFO:root: SARIMAX "
ts=2018-09-28T10:01:00.116+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 10:01:00,116 INFO:root: size of input: 288”
ts=2018-09-28T10:01:00.302+02:00 lvl=info msg=“http request” service=http host=::1 username=- start=2018-09-28T10:01:00.301950941+02:00 method=POST uri=/write?consistency=&db=telegraf&precision=ns&rp=autogen protocol=HTTP/1.1 status=204 referer=- user-agent=InfluxDBClient request-id=a35758fd-c2f4-11e8-811a-000000000000 duration=424.272µs
ts=2018-09-28T10:01:02.067+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 10:01:02,067 DEBUG:root: ORDER (1, 1, 0)”
ts=2018-09-28T10:01:03.683+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 10:01:03,683 DEBUG:root: SEASONAL (1, 1, 0, 4)”
ts=2018-09-28T10:01:03.882+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 10:01:03,882 DEBUG:root: MODEL <statsmodels.tsa.statespace.sarimax.SARIMAXResultsWrapper object at 0x7f6e49156b50>”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 10:01:03,895 DEBUG:root: 2018-09-28 08:05:00 282.365591”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:10:00 282.792357”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:15:00 283.584115”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:20:00 284.755152”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:25:00 286.338043”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:30:00 288.363462”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:35:00 290.847919”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:40:00 293.793276”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:45:00 297.226986”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:50:00 301.175528”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:55:00 305.648415”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:00:00 310.637916”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:05:00 316.167593”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:10:00 322.260748”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:15:00 328.921529”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:20:00 336.134828”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:25:00 343.921260”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:30:00 352.301740”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:35:00 361.276325”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:40:00 370.824244”
ts=2018-09-28T10:01:03.905+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“Freq: 5T, dtype: float64”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 10:01:03,905 DEBUG:root: forecast 2018-09-28 08:05:00 282.365591”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:10:00 282.792357”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:15:00 283.584115”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:20:00 284.755152”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:25:00 286.338043”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:30:00 288.363462”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:35:00 290.847919”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:40:00 293.793276”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:45:00 297.226986”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:50:00 301.175528”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 08:55:00 305.648415”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:00:00 310.637916”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:05:00 316.167593”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:10:00 322.260748”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:15:00 328.921529”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:20:00 336.134828”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:25:00 343.921260”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:30:00 352.301740”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:35:00 361.276325”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 09:40:00 370.824244”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“Freq: 5T, dtype: float64”
ts=2018-09-28T10:01:03.907+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 10:01:03,907 DEBUG:root: size of forecast 20”
ts=2018-09-28T10:01:03.911+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=“2018-09-28 10:01:03,911 INFO:root: Agent finished”
ts=2018-09-28T10:01:03.997+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=” This problem is unconstrained."
ts=2018-09-28T10:01:03.997+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=" This problem is unconstrained."
ts=2018-09-28T10:01:03.997+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=" Bad direction in the line search;"
ts=2018-09-28T10:01:03.997+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=" refresh the lbfgs memory and restart the iteration."
ts=2018-09-28T10:01:03.998+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=
ts=2018-09-28T10:01:03.998+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=" Bad direction in the line search;"
ts=2018-09-28T10:01:03.998+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=" refresh the lbfgs memory and restart the iteration."
ts=2018-09-28T10:01:03.998+02:00 lvl=info msg=“UDF log” service=kapacitor task_master=main task=sarimax_temp_stat node=sarimax2 text=" This problem is unconstrained."
After One batch, I have this error, @pdl86 @daria_kts @pauldix @nathaniel
