Good day.
I have a problem.
I have an esp32 that feeds values to a server with InfluxDB 2.
If I see the values in “Data explore” everything works fine
But as soon as I create the dashboard the values after a while stop being displayed and the graph stops
If I go to data explore again, the values are shown there normally
Hello
In data explore, I select the parameter I want.
I set the update for 5 seconds and an interval of 5 minutes
And press “Sumbit”
The graph is updated normally and within 5 hours there are no errors
Then I save this as a dashboard cell.
And for some time, the graph stops showing the accepted values.
line breaks
At the same time, everything is fine in data explore.
I also installed grafana and it also shows everything well
when i had multiple queries (let’s say to display 5x temperature curves), but the first return null, then the rest were not displayed. all works fine in explore but not in dashboard.
the solution was to check each query and be sure that first one will return some results.
