Hello.
My first post, so let me start off by thanking you all for this great SW that has served as my persistance storage service in my openHab smarthome.
After updating to influxdb 2.0.3 openHAB3 allready had a v2 interface addon ready, and my (inplace) upgrade from 1.8 something to 2.0.3 went (fairly) smooth.
My Grafana panels on the other hand, were all broken, and I abandoned using it since.
Lately I missed it and decided to give the latest Grafana 8.3.3 a spin.
I had it working with Flux, but it felt alien to me and I really want to use the old InfluxQL instead.
I have followed to descriptions creating v1 database to bucket mapping, and a v1 user Auth.
(Tried both using this v1 user Auth and/or the Header Auth method; same result)
I have no problem connecting from Grafana, but queries return just an empty string.
I suspect I might have done something wrong along the way, and any help would be greatly appreciated.
Here we go: bucket:
omr@shs2:~$omr@shs2:~$ influx v1 dbrp list
ID Database Bucket ID Retention Policy Default Organization ID
08c3b4d754a05000 openhab-db 69d6af7550af3294 Forever true 427da286ec49d684
08c3b5c681605000 openhab_db 69d6af7550af3294 Forever false 427da286ec49d684
08c3bb7cc5b43000 openhab 69d6af7550af3294 Forever true 427da286ec49d684
08c4d66bcdb43000 openhab_db 69d6af7550af3294 infinite true 427da286ec49d684
omr@shs2:~$ influx v1 auth list
ID Description Name / Token User Name User ID Permissions
08c4002beef43000 openhab openhab 06f1f3ef50380000 [write:orgs/427da286ec49d684/buckets/69d6af7550af3294]
omr@shs2:~$ curl --get http://localhost:8086/query?db=openhab_db --header "Authorization: Token c5heYDTRfynpj3UkQleV4s9N3b6LDRVdcTKMRoJyH1J0oLom3qZQivjOnwPsIcjjMqX7XX9td3x-rE674s-CBw==" --data-urlencode "q=SELECT used_percent FROM openhab_db.Forever.BathTemperature WHERE host=host1"
{"results":[{"statement_id":0}]}
omr@shs2:~$
As you can see I have tried retention with both Forever & infinite. Same result.
My openHab3 have no problem querying the same measurement: (probably using flux?)
(wanted to show you an image, but forum does not allow me as I have used up my 1 image.
PS. Grafana forum allows 2…
