Can we write and run influxql queries on influxdb 2.7.4.
If yes, how can we do that?
@cslm Yes, it’s possible: Query data with InfluxQL | InfluxDB OSS v2 Documentation
Hello Scott,
Is it possible to add influxdb2.7.4 as influxql datasource to grafana?
So that i can write influxql queries on grafana for influxdb2.7.4.
Hi @cslm
Yes, when you add the InfluxDB v2.7.4 Datasource in Grafana, you will be prompted to choose InfluxQL, Flux or SQL (SQL will only appear if you are using a very recent version of Grafana). Choose InfluxQL.
Hello @grant1,
I try to add it with influxql but getting error.
“InfluxDB returned error: Unauthorized error reading influxDB”
Are you sure that your instance of Grafana can “see” the InfluxDB instance at 164.92.152.44:8086? (if you are running Grafana OSS locally, can you ping this IP address?)
Also, do you have an Organization name and Default Bucket name specified in the lowermost section?
I can add datasource if i choose flux.
But i want to add as influxql.
If i choose influxql influxdb details area is as below :
If i choose Flux :
But i need influxql.
If you want i can share you ip adress and user pass of grafana and influx so you can login and check.
Perfect @grant1.
Thanks a lot. I checked. It is working.
Thanks @grant1, it works for me too!
