I have multiple telegraf config files in C:\Program Files\Telegraf\Config, one of them included a section with inputs.win_services. I added a new file to this folder and tested to confirm it works using .\telegraf --test .... but it wasn’t writing into influxdb.
I realised that the inputs.win_services section was failing due to a recent change caused the account I was using to lose privileges the service manager. Once I resolved this the data from my additional config began writing into influxdb.
Is this expected behaviour, or a bug? It seems to me that just because one config file is in error state all the other configs should continue to work.
I don’t receive any error for the additional config, it either silently fails or is ignored. I get an access denied to the service manager error for the config that is in error state.
Yeah this isn’t my issue, maybe I wasn’t clear in my first post. My problem is I have multiple config files - some work, one fails and one is failing silently or being ignored. I suspect it’s an ordering problem.
windows_server_performance_counters.conf - works
windows_server_web_services.conf - works
windows_server_services.conf - fails and records error
windows_server_application_metrics.conf - fails silently or is ignored
I can fix or remove the 3rd config and then the 4th one would work, but I would expect the 4th to continue working despite any of the previous ones failing. Changes in an environment could cause one to fail and it may not be identified (or fixed) immediately so the rest should continue to work.
the file order is not an issue, the files will be concatenated into a single file, and logically executed based on the plugin type input/processor/aggregators/output.
A possible issue might be something missing in the config itself, the equivalent of a quote that is opened but never closed… making everything that comes after a simple string…
About the failures, this is my experience so far:
the agent won’t start or won’t work at all only for config parsing errors
A plugin failure is always scoped to the plugin itself, as plugins are independent of each other
therefore I expect the issue to be:
the file is not loaded at all
something weird in the config once merged, that is syntactically valid but not actually working
I suggest you run the agent with a higher logging detail, and by logging to a file, to have the overall picture
