Issues with UDF function in kapacitor.conf file.
I am trying to run a basic python script using UDF function through Kapacitor.
Here are the steps followed:
- Created a simple Python script that queries the Influxdb measurement ‘disk’.
tTest.py script:
def main():
import os
os.system(‘curl -G 'http://172.19.99.31:8086/query?db=test\’ --data-urlencode 'q=select * from disk where used_percent=31' > /home/kapacitor/result.txt ')
if name==“main”:
main()
- Configures the UDF function in kapacitor.conf file as:
Kapacitor.conf
[[influxdb]]
enabled = true
default = true
name = “test”
urls = [“http://172.19.99.31:8086”]
[udf]
Configuration for UDFs (User Defined Functions)
[udf.functions]
[udf.functions.tTest]
# Run python
prog = “/usr/bin/python2”
args = [“-u”, “/tmp/kapacitor_udf/tTest.py”]
timeout = “10s”
- TICK file:
dbrp “test”.“autogen”
var data = stream
|from()
.measurement(‘disk’)
|window()
.period(5m)
.every(5m)
On defining the TICK script, below error pops up:
root@kapacitor:/etc/kapacitor# kapacitor define cpu_alert -tick cpu_alert.tick
Post http://localhost:9092/kapacitor/v1/tasks: dial tcp 127.0.0.1:9092: connect: connection refused
However, if i disable the UDF function configuration in kapacitor.conf file and update the tick script to execute the Python program as below, the python script runs fine.
TICK script with exec() function:
stream
|from()
|alert()
.crit(lambda: int(“used_percent”) = 31)
// Whenever we get an alert write it to a file.
.exec(‘/usr/bin/python’,‘/tmp/kapacitor_udf/tTest.py’)
.log(‘/tmp/alerts.log’)
Please note that the Influx db and Kapacitor are on different machines as below:
kapacitor: 172.19.99.38
influxdb: 172.19.99.31
