I’m trying to make the switch from 1 to 2 (official docker container; Running Docker Desktop + Ubuntu in WSL2) and getting a permission denied issue during the db upgrade procedure:
{“level”:“error”,“ts”:1628254367.3688755,“caller”:“upgrade/upgrade.go:467”,“msg”:“Database upgrade error, removing data”,“error”:“error getting size of /var/lib/influxdb/data: open /var/lib/influxdb/data/_internal: permission denied”,“stacktrace”:“github .com/influxdata/influxdb/v2/cmd/influxd/upgrade.runUpgradeE\n\t/home/circleci/go/src/github .com/influxdata/influxdb/cmd/influxd/upgrade/upgrade.go:467\ngithub .com/influxdata/influxdb/v2/cmd/influxd/upgrade.NewCommand.func1\n\t/home/circleci/go/src/github.com/influxdata/influxdb/cmd/influxd/upgrade/upgrade.go:157\ngithub .com/spf13/cobra.(*Command).execute\n\t/home/circleci/go/pkg/mod/github.com/spf13/cobra@v1.0.0/command.go:842\ngithub .com/spf13/cobra.(*Command).ExecuteC\n\t/home/circleci/go/pkg/mod/github.com/spf13/cobra@v1.0.0/command.go:950\ngithub .com/spf13/cobra.(*Command).Execute\n\t/home/circleci/go/pkg/mod/github.com/spf13/cobra@v1.0.0/command.go:887\nmain.main\n\t/home/circleci/go/src/github.com/influxdata/influxdb/cmd/influxd/main.go:53\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:204”}
I was running the previous 1.x version with all mounts running as a non root user (“scott”), and during the upgrade process previous to the above error I was getting the perm denied error for a different db:
“error getting size of /var/lib/influxdb/data: open /var/lib/influxdb/data/telegraf: permission denied”
I ls -al and noticed all folders/files were under the user “scott” while the new folders/files so far during the upgrade were “root”, so I went and chown -R root:root <all stuff owned by scott> and retried the upgrade, which then led to the previous error.
As of now, all folders/files are listed as owned by ‘root’, but still get the permission denied error.
Here’s my current tree:
scott@my-Cloud:/opt/docker/configs/InfluxDB$ ls
data meta v2 wal
scott@my-Cloud:/opt/docker/configs/InfluxDB$ ls -al
total 24
drwxr-xr-x 6 root root 4096 Aug 5 01:30 .
drwxrwxrwx 70 scott scott 4096 Jul 26 23:28 ..
drwxr-xr-x 5 root root 4096 Mar 23 22:38 data
drwxr-xr-x 2 root root 4096 Aug 4 19:23 meta
drwxr-xr-x 4 root root 4096 Aug 5 01:30 v2
drwx------ 5 root root 4096 Mar 23 22:38 wal
scott@my-Cloud:/opt/docker/configs/InfluxDB$ cd data/
scott@my-Cloud:/opt/docker/configs/InfluxDB/data$ ls -al
total 20
drwxr-xr-x 5 root root 4096 Mar 23 22:38 .
drwxr-xr-x 6 root root 4096 Aug 5 01:30 ..
drwx------ 4 root root 4096 Jan 29 2021 _internal
drwx------ 3 root root 4096 Mar 26 21:25 telegraf
drwx------ 4 root root 4096 Feb 4 2021 varken
scott@my-Cloud:/opt/docker/configs/InfluxDB/data$ cd _internal/
-bash: cd: _internal/: Permission denied
scott@my-Cloud:/opt/docker/configs/InfluxDB/data$ sudo -s
root@my-Cloud:/opt/docker/configs/InfluxDB/data# ls -la
total 20
root@my-Cloud:/opt/docker/configs/InfluxDB/data# cd _internal/
root@my-Cloud:/opt/docker/configs/InfluxDB/data/_internal# ls -la
total 16
drwx------ 4 root root 4096 Jan 29 2021 .
drwxr-xr-x 5 root root 4096 Mar 23 22:38 ..
drwxr-xr-x 10 root root 4096 Jan 29 2021 _series
drwx------ 9 root root 4096 Aug 4 19:23 monitor
and my current Compose:
influxdb:
hostname: influxdb
image: influxdb:latest
environment:
TZ: ${TZ}
DOCKER_INFLUXDB_INIT_USERNAME: 'Scott'
DOCKER_INFLUXDB_INIT_PASSWORD: "redacted"
DOCKER_INFLUXDB_INIT_ORG: "J. Scott Elblein"
DOCKER_INFLUXDB_INIT_BUCKET: "default_bucket"
DOCKER_INFLUXDB_INIT_RETENTION: ''
DOCKER_INFLUXDB_INIT_ADMIN_TOKEN: ''
DOCKER_INFLUXDB_INIT_MODE: 'upgrade'
volumes:
- /opt/docker/configs/InfluxDB:/var/lib/influxdb:rw
- /opt/docker/configs/InfluxDB/v2/data:/var/lib/influxdb2:rw
- /opt/docker/configs/InfluxDB/v2/conf:/etc/influxdb2:rw
- /etc/localtime:/etc/localtime:ro
networks:
- odb
deploy:
mode: replicated
replicas: 1
placement:
constraints:
- node.labels.MainDaemon == true
restart_policy:
condition: any
Admittedly, I’m not the most experienced Linux user on the planet, and this is a permissions issue so I assume it’s a fairly easy fix, but I’m not sure what it is?
