How can i view the percision setting for each db?
Hi @ntbritton ,
the precision on database level , for the moment , is always nanoseconds
best regards
I am looking for away to know what the setting is. I am unsure if there have been updates to the defaults. How can i check that setting?
The setting is nanaoseconds because the defaults cannot be changed on database level .
so the percision command is a global change?
Such as “percision s”
in influx you mean ?
Like
influx -database telegraf
> precision s
> insert precisiontest field1=30
> select * from precisiontest
time field1
1555495327 30
> precision ns
time field1
1555495327000000000 30
> insert precisiontest field1=40
time field1
1555495360531353155 40
that only affects your current session …
okay. I was thinking it would change the setting for the db, and that would then force all entries to seconds.
I am trying to push a bunch of historical data, that will be charted using graphna. What i am seeing is that only points in ns are showing up and not the historical ones in seconds that i am pushing.
Am i missing something?
I am doing this from powershell and getting the data 2018-05 to present as a ns number is difficult.
Probably the data you are pushing is dropped ?
If you insert records with a precision in seconds for example : 1555496690,
the database will think the year is 1970 …
> precision ns
> insert precisiontest field="ns" 1555496690000000000
> insert precisiontest field="s" 1555496690
ERR: {"error":"partial write: points beyond retention policy dropped=1"}
> show retention policies
name duration shardGroupDuration replicaN default
autogen 720h0m0s 168h0m0s 1 true
> alter retention policy autogen on telegraf duration inf
> precision rfc3339
time field
1970-01-01T00:00:01.55549669Z s
2019-04-17T10:24:50Z ns
You could use telegraf to ingest the data because in telegraf you can specify a precision …
It is also a good idea to temporarily enlarge the shard duration before ingesting your historical data
So in short, i need to figure out how to get the date to be a nanosecond date right?
If so any idea how one can do that in powershell?
Hi some examples …
echo ([int64]((Get-Date(“04/17/2019 10:00:05”))-(Get-Date -Date ‘1/1/1970’)).TotalMilliseconds * 1000000)
echo ([int64]((Get-Date(“05/01/2018”))-(Get-Date -Date ‘1/1/1970’)).TotalMilliseconds * 1000000)
echo ([int64]((Get-Date -Year 2019 -month 5)-(Get-Date -Date ‘1/1/1970’)).TotalMilliseconds * 1000000)
I went another way, since i dont need the nanosecond time.
i used this for the uri ‘http://server:8086/write?db=Database&precision=s’
