Parsing TASMOTA timestamp in json_v2 payload
Hello All,
according to the documentation, the type of the time stamp (’ timestamp_format’) may be unix, unix_ms, unix_us, unix_ns, or the Go “reference time” (with the latter I do not understand what is meant).
From my TASMOTA device I get a timestamp in the JSON payload in the form “2023-10-20T12:34:56”. That’s the content of the ‘%timestamp%’ variable.
What do I have to do so that this time stamp is interpreted correctly by Telegraf?
Thanks!
conne914
Hello @conne914,
Thanks for your question. Please see the following resource:
Essentially you can use that as your format.
Hi Anaisdg,
thanks for the link! I haven’t had time to test it in full context yet, but at least I now understand the previously mysterious concept of the “go reference time format”.
At least I was able to successfully test “my own” timestamp format on the “playground”.
package main
import (
	"fmt"
	"time"
func parse(date string) {
	t, err := time.Parse("2006-01-02T15:04:05", date)
	if err != nil {
		panic(err)
	fmt.Println(t)
func main() {
	parse("2023-10-24T13:49:55")
Best,
conne914
