Hi everyone
Date format dd/mm/aaaa hh:mm:ss can’t parse
Normal or error from myself?
Hello @Gregory_Martin,
The timestamp format must comply with:
The csv_timestamp_column option specifies the key containing the time value and csv_timestamp_format must be set to unix , unix_ms , unix_us , unix_ns , or a format string in using the Go “reference time” which is defined to be the specific time : Mon Jan 2 15:04:05 MST 2006 (csv_timestamp_format = “2006-01-02T15:04:05Z07:00)”.
Does that help?
Thank you ![]()
Thanks, i found my error on base timestamp
Gregory MARTIN
