Telegraf Json Input unable to parse Date
Hi i have a test Json file with timestamp field as below
2019-03-06T11:19:48.0000855Z
I keep on getting below error when starting telegraf to read the json test file
2019-03-06T13:07:10Z E! [inputs.file]: Error in plugin: parsing time “2019-03-06T11:19:48.0000855Z”: month out of range
Any ideas how i can parse the dateformat as causing me a headache at the moment
My config is as below
[[inputs.file]]
files = [“D:/Logs/Apps/TeleGrafWindowsPerfMonAgent/TestJson.log”]
Data format to consume.
Each data format has its own unique set of configuration options, read
more about them here:
telegraf/docs/DATA_FORMATS_INPUT.md at master · influxdata/telegraf · GitHub
data_format = “json”
Query is a GJSON path that specifies a specific chunk of JSON to be
parsed, if not specified the whole document will be parsed.
GJSON query paths are described here:
GitHub - tidwall/gjson: Get JSON values quickly - JSON parser for Go
json_query = “”
Tag keys is an array of keys that should be added as tags.
tag_keys = [
“hostname”
String fields is an array of keys that should be added as string fields.
json_string_fields = [“CurrentItemSubscriptions”,“MaxItemSubscriptions”,“TotalSubscribedItems”,“Usernames”]
Name key is the key to use as the measurement name.
json_name_key = “LightStreamerJmxResource”
Time key is the key containing the time that should be used to create the
metric.
json_time_key = “timestamp”
Time format is the time layout that should be used to interprete the json_time_key.
The time must be unix, unix_ms, unix_us, unix_ns, or a time in the
“reference time”. To define a different format, arrange the values from
the “reference time” in the example to match the format you will be
using. For more information on the “reference time”, visit
time package - time - Go Packages
ex: json_time_format = “Mon Jan 2 15:04:05 -0700 MST 2006”
json_time_format = “2006-01-02T15:04:05Z07:00”
json_time_format = “01/02/2006 15:04:05”
json_time_format = “unix”
json_time_format = “unix_ms”
json_time_format = “2019-03-06T11:19:48.0000855Z”
Timezone allows you to provide an override for timestamps that
don’t already include an offset
e.g. 04/06/2016 12:41:45
Default: “” which renders UTC
Options are as follows:
1. Local – interpret based on machine localtime
2. “America/New_York” – Unix TZ values like those found in List of tz database time zones - Wikipedia
3. UTC – or blank/unspecified, will return timestamp in UTC
##json_timezone = “”
Make sure to use the so called “reference date” in your json_time_format, this is the exact date Mon Jan 2 15:04:05 -0700 MST 2006. I haven’t tested this but it should be:
json_time_format = "2006-01-02T15:04:05.000000Z"
To help clear this up… I had the same issue:
Telegraf.conf
[[inputs.file]]
   files = ["out.json"]
   json_time_key = "time"
   json_time_format = "2010-04-17T17:00:00.000Z"
out.json
{ "foo" : 2.0, "time": "2018-11-17T17:49:52.357Z"}
error
2019-04-19T20:52:20Z E! [inputs.file]: Error in plugin: parsing time "2018-11-17T17:49:52.357Z": month out of range
I selected an arbitrary date for telegraf.conf and the plugin requires that we use the reference date of "2006-01-02T15:04:05Z07:00
So, I needed to change telegraf.conf to
Telegraf.conf
[[inputs.file]]
   json_time_format = "2006-01-02T15:04:05Z07:00"
Which worked…
2019-04-19T21:05:16Z D! [agent] Starting service inputs
2019-04-19T21:05:30Z D! [outputs.influxdb] wrote batch of 1 metrics in 402.131078ms
2019-04-19T21:05:30Z D! [outputs.influxdb] buffer fullness: 1 / 10000 metrics.
2 years late but this helped resolve my issue. thanks @John_Sobanski !!
JSON itself does not specify how dates should be represented, but JavaScript does. What .NET does is a non-standard hack/extension. The problem with JSON date and really JavaScript in general – is that there’s no equivalent literal representation for dates. In JavaScript following Date constructor straight away converts the milliseconds since 1970 to Date as follows:
var jsonDate = new Date(1297246301973);
Then let’s convert it to js format:
var date = new Date(parseInt(jsonDate.substr(6)));
The substr() function takes out the /Date( part, and the parseInt() function gets the integer and ignores the )/ at the end. The resulting number is passed into the Date constructor .
For ISO-8601 formatted JSON dates, just pass the string into the Date constructor:
var date = new Date(jsonDate);
