Hello there!
My problem is probably simple but I cannot get my head around a solution.
In my Influx2.0 database I have two fields containing coordinates (Lng, Lat) which I need to handover to a local running API which gives me elevation- data (just one field containing a number). This result should then be put back in my database into the elevation- field at the same timestamp.
Is there a way to do this with telegram or should I use the python-client? And is there a way to limit the request to certain times? I have coordinatedata every 0.5 seconds, this would be way more dense than I need.
Edit: This is the response I get from the API, simple JSON:
“results”: [
“dataset”: “eudem25m”,
“elevation”: 13.213644981384277,
“location”: {
“lat”: 53.458991,
“lng”: 9.981662
“status”: “OK”
Thank you very much!
