Hey there,
I’m trying since multiple hours to get some JSON data into influxdb.
The problem is the following - this is how my JSON looks like:
"number":"FKAISS2141",
"time":"2018-12-03 13:18:32.897 +01:00",
"DATA":{
"SEQ":{
"X":"55.56722",
"Y":"-656.1673",
"Z":"3172.665",
"A":"72.68263",
"B":"25.55068",
"C":"-78.9617"
These values are coordinates, so I dont want them to be aggregated. Independently of that I need to cast/convert all the numbers in quotes to actual numbers. For this I’m using the following processor:
[[processors.converter]]
[processors.converter.fields]
float = ["DATA.SEQ.X", "DATA.SEQ.Y", "DATA.SQR.Z"]
But it seems like the processor does not convert the data types. Since I can’t apply any aggregation function in influx those values seem to be still strings. In addition I’m not sure about the json_string_fields and tag keys. And how should I call the fields in the processor? Is the GJSON-Rule already applied?
This is my whole config file:
[global_tags]
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
debug = false
quiet = false
logfile = ""
hostname = ""
omit_hostname = false
# OUTPUT PLUGINS #
[[outputs.influxdb]]
urls = ["http://influxdb_1:8086"]
database = "db01"
# INPUT PLUGINS #
[[inputs.kafka_consumer]]
name_override = "kfk_rbts310"
brokers = ["kafka01:9092"]
topics = ["rbts310ax"]
consumer_group = "telegraf_metrics_consumers"
offset = "newest"
data_format = "json"
json_query = "DATA.SEQ"
# tag_keys = ["X","Y","Z"]
json_string_fields = ["X","Y","Z"]
max_message_len = 100000000
float = ["DATA.SEQ.X", "DATA.SQE.Y", "DATA.SEQ.Z"]
Cheers
