Hey everyone, I’ve been having a significant problem with my InfluxDB docker setup. It seems that every time I start my container, the container’s memory skyrockets and the container exits with a 137 exit code (out of memory) before the service gets anywhere. We have hundreds of gigabytes of data stored, so loading it all into memory is not an option. What can I do to reduce the startup load and get InfluxDB running without trigger an OOM error?
I’ve found a few resources that mention out-of-memory problems: influxdb out of memory · Issue #13318 · influxdata/influxdb · GitHub, https://github.com/influxdata/influxdb/issues/24128. I’ve tried messing with the configuration parameters to no avail. I’ve also tried setting GODEBUG=madvdontneed=1 but that didn’t help either.
Here is the end of the docker logs:
2023-05-02 10:06:17 ts=2023-05-02T16:06:17.094979Z lvl=info msg="loading changes (start)" log_id=0hZJEXvW000 service=storage-engine engine=tsm1 op_name="field indices" op_event=start
2023-05-02 10:06:17 ts=2023-05-02T16:06:17.105109Z lvl=info msg="Opened file" log_id=0hZJEXvW000 service=storage-engine engine=tsm1 service=filestore path=/var/lib/influxdb2/engine/data/37612e6f882fd383/autogen/109/000000024-000000003.tsm id=0 duration=61.675ms
2023-05-02 10:06:17 ts=2023-05-02T16:06:17.119459Z lvl=info msg="Opened shard" log_id=0hZJEXvW000 service=storage-engine service=store op_name=tsdb_open index_version=tsi1 path=/var/lib/influxdb2/engine/data/37612e6f882fd383/autogen/109 duration=42524.077ms
2023-05-02 10:06:17 ts=2023-05-02T16:06:17.528501Z lvl=info msg="index opened with 8 partitions" log_id=0hZJEXvW000 service=storage-engine index=tsi
2023-05-02 10:06:17 ts=2023-05-02T16:06:17.537640Z lvl=info msg="loading changes (start)" log_id=0hZJEXvW000 service=storage-engine engine=tsm1 op_name="field indices" op_event=start
2023-05-02 10:06:17 ts=2023-05-02T16:06:17.791727Z lvl=info msg="loading changes (end)" log_id=0hZJEXvW000 service=storage-engine engine=tsm1 op_name="field indices" op_event=end op_elapsed=696.751ms
2023-05-02 10:06:17 ts=2023-05-02T16:06:17.847755Z lvl=info msg="Opened file" log_id=0hZJEXvW000 service=storage-engine engine=tsm1 service=filestore path=/var/lib/influxdb2/engine/data/37612e6f882fd383/autogen/292/000000001-000000001.tsm id=0 duration=9.282ms
2023-05-02 10:06:17 ts=2023-05-02T16:06:17.863249Z lvl=info msg="Opened shard" log_id=0hZJEXvW000 service=storage-engine service=store op_name=tsdb_open index_version=tsi1 path=/var/lib/influxdb2/engine/data/37612e6f882fd383/autogen/292 duration=1049.864ms
2023-05-02 10:06:18 ts=2023-05-02T16:06:18.341013Z lvl=info msg="index opened with 8 partitions" log_id=0hZJEXvW000 service=storage-engine index=tsi
2023-05-02 10:06:18 ts=2023-05-02T16:06:18.344178Z lvl=info msg="loading changes (start)" log_id=0hZJEXvW000 service=storage-engine engine=tsm1 op_name="field indices" op_event=start
