OpenVPN stats telegraf
Hi! Is it possible to collect metrics from OpenVPN? How to do it?
Hello @suicidesky92,
I’m not sure, but maybe try using this
or this with the python cl. Or you could try using the procstat telegraf plugin with
exe = "openvpn"
for the config option.
Best,
Anais
Well, there are some new projects on GitHub:
Most of them try to convert OpenVPN statistics logs into Influxdb data format.
