I created a Docker Swarm cluster lab with three Linux servers as virtual machines. I then deployed Telegraf in the swarm with deploy mode global and InfluxDB with 1 replica. This is only to illustrate the background scenario.
I have two Telegraf config files:
- main (telegraf.conf): it is used for gathering the swarm nodes performance data (cpu, memory, disk, diskio) by using the default input plugin.
- secondary (shellies.conf): it collects metrics data from a mqtt broker where some Shelly devices I own publish IOT data.
The main config file has omit_hostname = false in the agent section, this way I can get all performance data of three hosts forming the cluster separately or all together:
So far so good.
The problem is about the shellies bucket:
I am not interested in the Host field, it does matter anything with the Shelly IOT data. Those metrics are not relevant to the cluster nodes and (worse) those data are written three times, one each for every host.
Thank you.
