Hi.
I am ingesting below json data to my telegraf:
"BID": "1032",
"FID": "1032cucp1",
"beginTime": "1647453339",
"counters": {
"app": {
"OR.ENDC": {
"SgnbAddAttempt.eNB.0": "0.00",
"SgnbAddAttempt.eNB.1": "0.00",
"SgnbAddAttempt.eNB.2": "0.00",
"SgnbAddAttempt.eNB.3": "0.00"
"endTime": "1647436278",
"senderType": "CU-CP",
"Version": "6.0.0"
After applying a set of processor plugin i am getting following data:
om,BID=1032,FID=1032cucp1,cell=app,method=counters_a,name=counters_app_OR.ENDC_SgnbAddAttempt.eNB.3,senderType=CU-CP,Version=6.0.0 OR_ENDC_SgnbAddAttempt.eNB_3=0i 1647453339000000000
om,BID=1032,FID=1032cucp1,cell=app,method=counters_a,name=counters_app_OR.ENDC_SgnbAddAttempt.eNB.0,senderType=CU-CP,Version=6.0.0 OR_ENDC_SgnbAddAttempt.eNB_0=0i 1647453339000000000
om,BID=1032,FID=1032cucp1,cell=app,method=counters_a,name=counters_app_OR.ENDC_SgnbAddAttempt.eNB.2,senderType=CU-CP,Version=6.0.0 OR_ENDC_SgnbAddAttempt.eNB_2=0i 1647453339000000000
om,BID=1032,FID=1032cucp1,cell=app,method=counters_a,name=counters_app_OR.ENDC_SgnbAddAttempt.eNB.1,senderType=CU-CP,Version=6.0.0 OR_ENDC_SgnbAddAttempt.eNB_1=0i 1647453339000000000
Now i want to apply aggregate merge plugin in order to combine fields. Since here all measurement and tag name are same except method and name tag. So i am using tagexclude to exclude them.
[[aggregators.merge]]
## If true, the original metric will be dropped by the
## aggregator and will not get sent to the output plugins.
# taginclude = ["GNBID","VNFID","cell","cluster_id","host","senderType","swVersion"]
tagexclude = ["name","method"]
drop_original = true
period = "3m"
delay = "3m"
grace = "3m"
The actual vs expected output:
**Actual output:**
om,BID=1032,FID=1032cucp1,cell=app,method=counters_a,name=counters_app_OR.ENDC_SgnbAddAttempt.eNB.3,senderType=CU-CP,Version=6.0.0 value=0i 1647453339000000000
om,BID=1032,FID=1032cucp1,cell=app,method=counters_a,name=counters_app_OR.ENDC_SgnbAddAttempt.eNB.0,senderType=CU-CP,Version=6.0.0 value=0i 1647453339000000000
om,BID=1032,FID=1032cucp1,cell=app,method=counters_a,name=counters_app_OR.ENDC_SgnbAddAttempt.eNB.2,senderType=CU-CP,Version=6.0.0 value=0i 1647453339000000000
om,BID=1032,FID=1032cucp1,cell=app,method=counters_a,name=counters_app_OR.ENDC_SgnbAddAttempt.eNB.1,senderType=CU-CP,Version=6.0.0 value=0i 1647453339000000000
**Expected output:**
om,BID=1032,FID=1032cucp1,cell=app,senderType=CU-CP,Version=6.0.0 OR_ENDC_SgnbAddAttempt.eNB_0=0i,OR_ENDC_SgnbAddAttempt.eNB_1=0i,OR_ENDC_SgnbAddAttempt.eNB_2=0i,OR_ENDC_SgnbAddAttempt.eNB_3=0i 1647453339000000000
According to me tagexclude should work and since all other tags except method and name are same we should be getting multiple field in single series.
Is there anything wrong with what i am doing here?
