I am trying to use the logparser plugin with the histogram aggregator plugin but can’t get it to work.
What am I missing here?
Here is my config:
[agent]
interval = "5s"
[[outputs.file]]
files = ["stdout"]
[[aggregators.histogram]]
period = "10s"
drop_original = false
[[aggregators.histogram.config]]
buckets = [0.0, 100.0, 200.0, 300.0, 400.0, 500.0]
measurement_name = "testmetric"
fields = ["resp_code"]
buckets = [0.0, 15.6, 34.5, 49.1, 71.5, 80.5, 94.5, 100.0]
measurement_name = "cpu"
[[inputs.cpu]]
percpu = false
totalcpu = true
[[inputs.logparser]]
files = ["/tmp/test.log"]
from_beginning = false
name_override = "testmetric"
[inputs.logparser.grok]
patterns = ["%{COMBINED_LOG_FORMAT}"]
To test echo some log lines:
echo '127.0.0.1 ident auth [10/Oct/2000:13:55:36 -0700] "GET /apache_pb.gif HTTP/1.0" 200 2326 "http://localhost:8083/" "Chrome/51.0.2704.84"' >> /tmp/test.log
But I never see logparser metrics aggregated through histogram. I do see the cpu metrics however. Output:
2017-09-26T16:43:45Z I! Starting Telegraf v1.4.0
2017-09-26T16:43:45Z I! Loaded outputs: file
2017-09-26T16:43:45Z I! Loaded inputs: inputs.cpu inputs.logparser
2017-09-26T16:43:45Z I! Tags enabled: host=ip-10-129-88-74.vpc.internal
2017-09-26T16:43:45Z I! Agent Config: Interval:5s, Quiet:false, Hostname:"ip-10-129-88-74.vpc.internal", Flush Interval:10s
testmetric,verb=GET,resp_code=200,path=/tmp/test.log,host=ip-10-129-88-74.vpc.internal resp_bytes=2326i,agent="Chrome/51.0.2704.84",client_ip="127.0.0.1",ident="ident",http_version=1,auth="auth",request="/apache_pb.gif",referrer="http://localhost:8083/" 971211336000000000
testmetric,path=/tmp/test.log,host=ip-10-129-88-74.vpc.internal,verb=GET,resp_code=200 auth="auth",resp_bytes=2326i,referrer="http://localhost:8083/",agent="Chrome/51.0.2704.84",client_ip="127.0.0.1",request="/apache_pb.gif",http_version=1,ident="ident" 971211336001000000
cpu,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal usage_idle=99.59839357450608,usage_nice=0,usage_iowait=0,usage_irq=0,usage_steal=0,usage_guest_nice=0,usage_user=0.4016064257039481,usage_system=0,usage_softirq=0,usage_guest=0 1506444235000000000
cpu,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal usage_guest=0,usage_guest_nice=0,usage_user=0,usage_iowait=0,usage_softirq=0,usage_steal=0,usage_system=0,usage_idle=100,usage_nice=0,usage_irq=0 1506444240000000000
cpu,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal usage_user_min=0.4016064257039481,usage_softirq_min=0,usage_guest_max=0,usage_idle_max=99.59839357450608,usage_guest_min=0,usage_irq_min=0,usage_guest_nice_max=0,usage_steal_min=0,usage_iowait_max=0,usage_system_min=0,usage_nice_max=0,usage_iowait_min=0,usage_steal_max=0,usage_user_max=0.4016064257039481,usage_system_max=0,usage_softirq_max=0,usage_nice_min=0,usage_idle_min=99.59839357450608,usage_irq_max=0,usage_guest_nice_min=0 1506444240000000000
cpu,le=0,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal usage_irq_bucket=1i,usage_user_bucket=0i,usage_softirq_bucket=1i,usage_iowait_bucket=1i,usage_nice_bucket=1i,usage_idle_bucket=0i,usage_steal_bucket=1i,usage_guest_nice_bucket=1i,usage_guest_bucket=1i,usage_system_bucket=1i 1506444240000000000
cpu,host=ip-10-129-88-74.vpc.internal,le=15.6,cpu=cpu-total usage_guest_nice_bucket=1i,usage_iowait_bucket=1i,usage_nice_bucket=1i,usage_user_bucket=1i,usage_system_bucket=1i,usage_steal_bucket=1i,usage_guest_bucket=1i,usage_irq_bucket=1i,usage_softirq_bucket=1i,usage_idle_bucket=0i 1506444240000000000
cpu,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal,le=34.5 usage_nice_bucket=1i,usage_idle_bucket=0i,usage_irq_bucket=1i,usage_softirq_bucket=1i,usage_iowait_bucket=1i,usage_system_bucket=1i,usage_user_bucket=1i,usage_guest_bucket=1i,usage_steal_bucket=1i,usage_guest_nice_bucket=1i 1506444240000000000
cpu,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal,le=49.1 usage_idle_bucket=0i,usage_softirq_bucket=1i,usage_steal_bucket=1i,usage_user_bucket=1i,usage_iowait_bucket=1i,usage_guest_bucket=1i,usage_irq_bucket=1i,usage_nice_bucket=1i,usage_system_bucket=1i,usage_guest_nice_bucket=1i 1506444240000000000
cpu,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal,le=71.5 usage_system_bucket=1i,usage_irq_bucket=1i,usage_iowait_bucket=1i,usage_user_bucket=1i,usage_softirq_bucket=1i,usage_guest_nice_bucket=1i,usage_nice_bucket=1i,usage_idle_bucket=0i,usage_steal_bucket=1i,usage_guest_bucket=1i 1506444240000000000
cpu,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal,le=80.5 usage_guest_nice_bucket=1i,usage_nice_bucket=1i,usage_system_bucket=1i,usage_irq_bucket=1i,usage_steal_bucket=1i,usage_idle_bucket=0i,usage_iowait_bucket=1i,usage_user_bucket=1i,usage_softirq_bucket=1i,usage_guest_bucket=1i 1506444240000000000
cpu,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal,le=94.5 usage_iowait_bucket=1i,usage_guest_bucket=1i,usage_irq_bucket=1i,usage_user_bucket=1i,usage_system_bucket=1i,usage_idle_bucket=0i,usage_steal_bucket=1i,usage_guest_nice_bucket=1i,usage_nice_bucket=1i,usage_softirq_bucket=1i 1506444240000000000
cpu,cpu=cpu-total,host=ip-10-129-88-74.vpc.internal,le=100 usage_guest_bucket=1i,usage_guest_nice_bucket=1i,usage_irq_bucket=1i,usage_softirq_bucket=1i,usage_user_bucket=1i,usage_system_bucket=1i,usage_idle_bucket=1i,usage_steal_bucket=1i,usage_iowait_bucket=1i,usage_nice_bucket=1i 1506444240000000000
cpu,host=ip-10-129-88-74.vpc.internal,le=+Inf,cpu=cpu-total usage_iowait_bucket=1i,usage_steal_bucket=1i,usage_guest_nice_bucket=1i,usage_guest_bucket=1i,usage_nice_bucket=1i,usage_idle_bucket=1i,usage_irq_bucket=1i,usage_softirq_bucket=1i,usage_system_bucket=1i,usage_user_bucket=1i 1506444240000000000
