Hello to everyone,
I’m a new user of flux, and it’s really hard to understand.
I’d like to create dynamic dashboard in Grafana. The goal is to have, for example, the hostname of a router, when I select his location from a first picker.
I setup two variable :
For the location :
from(bucket: “telegraf/autogen”)
|> filter(fn: (r) => r["_measurement"] == “snmp”)
|> filter(fn: (r) => r["_field"] == “Localisation”)
|> keep(columns: ["_value"])
|> distinct()
|> yield(name: “distinct”)
My picker is ok, I can show al locations of my routers. Now I want to have a second picker updated. I create a new variable like that :
|> filter(fn: (r) => r["_field"] == “$location”)
|> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: “_value”)
|> group()
|> distinct(column: “hostname”)
But it return “none”.
The sad thing is I’m able to do the revert (start from hostname to have localisation), but it’s not what I need.
Could you help me with this ?
Regards,
Tiki_
