Grafana shows 'no data' when check more than one choose in variable
Hi all,
Can you help to share some steps to implement the variable/template in Grafana7.3 with influxdb2.0-rc3 ? Thank you.
When I add a tag filter in the query cmd (add ‘r.host == “${host}”’), the grafana has the right action. No matter which one host I selecte, it shows the right host data. But if I select more than one host, it shows no data (no error shows).
from(bucket: “flower”)
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
|> filter(fn: ® =>
r._measurement == “mem” and
r.host == “${host}” and
r._field == “used_percent”
I only post a thread in grafana community but I’m not sure whether this is a grafana problem or influxdb2.0 problem.
Hello @wolfohyeah,
I’m not sure either. I know that if you wanted to filter for multiple hosts with flux your query would look like this:
|> range(start: -30d)
|> filter(fn: (r) =>
r.host == “host1” or
r.host == “host2” and
Hi @Anaisdg,
Thank you for you reply. My problem is that if I have thousands of hosts, it’s impossible to write all host in the filter. Instead we need a variable to filter the search.
In the dashboard inner influxdb2.0, I can set the variable like this:
|> filter(fn: (r) => r[“_measurement”] == “mem”)
|> filter(fn: (r) => r[“_field”] == “used_percent”)
|> filter(fn: (r) => r.host == v.ahost)
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: “last”)
But I don’t know how to write the query cmd in grafana.
Hello @wolfohyeah,
I don’t know either. I’m not that familiar with grafana, but I feel like (without being sure) this is a feature specific to InfluxDB. Have you tried asking on the grafana community? I’ll ask around.
Did you try the following
|> filter(fn: ® => r[“host”] =~ /.*/)
Also there is an option in grafana called Include All Option and you specify the regex
The solution:
In the Grafana query to get the tag values ​​for the variable:
schema.tagValues(bucket: "flower", tag: "host")
In Grafana’s query:
from(bucket: "flower")
|> filter(fn: (r) => r["_measurement"] == "mem")
|> filter(fn: (r) => r["_field"] == "used_percent")
|> filter(fn: (r) => contains(value: r["host"], set: ${host:json}))
Where set: ${host:json} is the name of the variable. Adding attribute :json you can select multiple values ​​in variable.
Regards !! :wave:
Yes. That works fine by using contains. Thanks @delapuentem and @Anaisdg and @Ashish_Sikarwar .
Hi @delapuentem , I have another problem with multiple variables. My measurement looks like below:
name1=animal,name2=tiger count=20
name1=animal,name2=lion count=25
name1=fruit,name2=apple count=10
name1=fruit,name2=banana count=15
name1 and name2 are my tags and count is my field.
In influxdb2.0.6, I create 2 variable:
variable name1:
import “influxdata/influxdb/schema”
schema.tagValues(bucket:“mybucket”, tag:“name1”)
variable name2:
schema.tagValues(bucket:“mybucket”, tag:“name2”)
In grafana 7.5.7(also tried 8.0.0-beta2) , I create 2 variables named query1 and query2:
query1(enable multi-value):
import “influxdata/influxdb/v1”
v1.tagValues(
buket: v.bucket,
tag: “name1”,
predicate: (r) => true,
start: -1d
query2(enable multi-value):
v1.tagValues(
buket: v.bucket,
tag: “name2”,
predicate: (r) => r.name1 == “${query1}”,
start: -1d
What I want is that the item of query2 should be based on the selection of query1.
eg. If I only select animal, the item list of query2 should only include animal item like tiger and lion but not banana. And if I select both animal and fruit in query1, the item list of query2 should display all animals and fruits(in my example above they are tiger/lion/apply/banana).
My query in grafana looks like below:
from(bucket: “mybucket”)
|> filter(fn:(r) => r._measurement == “mymeasurement” and r._field == “count”
and contains(value: r.name2, set:${query2:json}))
In my grafana dashboard, when I select only one item of query1 let’s say animal, I can see tiger and lion in query2 drop-down items. And it works well if i select one or more item in query2.
The problem is that if I select more than one item in query1, I see nothing in query2 drop-down item.
I know that the problem is happened in my query command of query2 or name2. But I don’t know how to fix it out.
Many thanks.
@jorgedlcruz Any chance you can help here please?
Hello, I am afraid I am not that versatile with Flux just yet, I need more time to play with it. My apologies :frowning:
Hi @Anaisdg , Can influxdb dashboard reach my point as I describe above ?
Hi @wolfohyeah . Sorry for taking so long to answer. I don’t know if you still have this problem.
I give you a solution:
name1
|> range(start: v.timeRangeStart)
|> filter(fn: (r) => r["_measurement"] == “mymesurement”)
|> keyValues(keyColumns: [“name1”])
|> group()
|> keep(columns: [“name1”])
|> distinct(column: “name1”)
name2
|> filter(fn: (r) => r[“name1”] =~ /^${name1:regex}$/)
|> keyValues(keyColumns: [“name2”])
|> group()
|> keep(columns: [“name2”])
|> distinct(column: “name2”)
The solution is in this line:
It is what makes the variables hierarchical, and the value of this variable changes according to the previous variable. This supports the “All” parameter, the Multi-select and single values ​​in Grafana.
