How to get Grafana dashboard variables into flux query?
in influxdb 1.x I used a dashboard variable to repeat a row of a dashboard.
In influxdb 1.x during creation of the query I get a popup window to choose variables from.
Now in influxdb 2.0 and flux queries I don’t know how to access the dashboard variables to get repeated rows as well:
Grafana_InfluxDB20_repeatrows
I tried also:
|> filter(fn: (r) => r["host"] == ${myvariable})
but got this error:
invalid: compilation failed: error at @8:37-8:38: invalid expression: invalid token for primary expression: ILLEGAL
Can someone please tell me how to get the variable into my flux query?
Thanks a lot…
I don’t know if it works the same way in Grafana, but in InfluxDB 2.0 it just does:
r["host"] == v.myvariable
Hi Franky,
I tried this as well, but it gives me:
invalid: error @8:37-8:38: undefined identifier v
if I just enter v. then I get a list of variables I can choose from like
v.defaultBucket
v.organization
v.timeRangeStart
v.timeRangeStop
etc.
But my dashboard variable is not within this list.
I think you should rather ask the question in the Grafana forum, because I think this is a Grafana problem, how the variables come from the dashboard into the flux queries and how they are called there?
Hi Frank,
yes - I did already.
Try it with:
r["host"] == "${myvariable}"
or:
r["host"] == "myvariable"
Hi Franky,
the 1st one I tried already (I mentioned in my 1st post).
The 2nd one gives me:
invalid: error @8:37-8:49: undefined identifier myvariable
Meantime I found it by myself, instead of:
it shoud be:
|> filter(fn: (r) => r["host"] == "${myvariable}")
This is what Franky suggested but I forgot the quotes in my test.
So I just missed the quotes - hope that helps someone
This above mentioned line is the solution (the quotes are important)
Hey @Franky1 and @T_Burns,
I have managed to replicate the call of Grafana variables as you stated.
Now i want to build it into a part of a text. What i want to do is a Query that looks like this:
Variable="${MyVariable}"
from(bucket: “MyBucket”)
|> filter(fn: (r) =>
r._measurement == "MyMeasurement" and
r.Generic_Name == "Weight_Indicator_Machine_**{Variable}**"
I couldn’t make it work. Do you have any ideas how this might work?
I hope, it is not working for all. The above syntax does not give me any result though there is no error.
|> filter(fn: (r) => r["host"] == "${data_nodes_prod}")
Instead if I give the following pattern it works fine. I don’t understand what’s the problem exactly.
|> filter(fn: (r) => contains(value: r["host"], set: ${data_nodes_prod:json}))
Any views?
great, thanks! using the contains(value: r["host"], set: ${data_nodes_prod:json} syntax worked a treat. thanks!
filter(fn: (r) => r[“host”] =~ /${data_nodes_prod:regex}/
that has superior performance to “contains” and does the same thing
