Hi there,
I’m new to Flux and try to visualize my data in an easy way to the user.
I’ve a lot of measurements and want to give the user the ability to filter for measurement (devicename in my case), customer and consumer. For each I got variables in Grafana, filled from queries e.g.
Variable: measurement
import “influxdata/influxdb/schema”
schema.measurements(bucket: “buckeeet”)
Custom all value = “All”
Now if I want to see some data in grafana my query took > 30 seconds
from(bucket: “buckeeet”)
|> filter(fn: (r) =>
(if “${measurements}” != “All” then r._measurement == “${measurements}” else r._measurement != “”) and
(if “${customer}” != “All” then r.customer == “${customer}” else r.customer != “”) and
(if “${consumer}” != “All” then r.consumer == “${consumer}” else r.consumer != “”) and
(r._field == “voltage”)
|> yield(name: “mean”)
When the query is static and looks like the followed, I tooks 1 - 3 seconds (3 seconds for max series of 1000) to get a result.
|> filter(fn: (r) =>
r._measurement != “” and
r.customer == “secret” and
r.consumer != “” and
|> yield(name: “mean”)
Can someone help me to optimize it? I don’t found a solution online.
