Nested Loops Filtering with Grafana Variables
My goal is something like this:
data.filter(item => {
    foreach compareItem in compareCollection
        if(item equals compareItem) return true;
        return false;
I am working with Grafana and the variable ${measurements} can either have 1 or multiple strings
my query right now looks like this:
from(bucket: "MachineBucket")
  |> filter(fn: (r) => contains(value: r["_measurement"], set: "${measurements}"))
  |> drop(columns: ["_start", "_stop"])
  |> yield()
it tells me that it cannot iterate over a single item/collection of strings
EDIT: i made progress by changing “${measurements}” to ["${measurements}"].
It is now able to query a single measurement, but can still not query multiple because it writes writes the collection of measurments out as: ["{object1,object2,object3}"].
I think you can filter this with regex.
  • So first create a Grafana template variable with the measurement names.
  • Then use the template variable with a regex filter and the regex format, like the following:
  |> filter(fn: (r) => r["_measurement"] =~ /${measurements:regex}/)
  |> yield()
I hope this helps.
I think what you are describing is filtering the data based on the regex in the variable measurements, but that is not the behaviour im aiming for. Pls correct me if i am wrong on this.
I want to filter my query based on a collection or rather repetition of strings (i also get the strings from another query). But i appreciate the help.
@Rush_Ferchau Because Grafana returns the set as a string, it takes some string manipulation to transform the variable value into a Flux array. This should work:
import "array"
import "regexp"
import "strings"
measurementSet = strings.split(v: regexp.replaceAllString(r: /[\{\}]/, v: "${measurements}", t: ""), t: ",")
    |> filter(fn: (r) => contains(value: r._measurement, set: measurementSet))
You are my hero, this solved my Problem :smiley:
