Hi there,
I hope you can help because I’m out of ideas.
I’ve deployed an InfluxDB in my kubernetes and the UI is working fine.
I’ve wrote a small C# program to test the insertion of a record. My model looks like this:
public class AgentLoggedState
[Column("UTCOperationDate", IsTimestamp =true)]
public DateTime UTCOperationDate { get; set; }
[Column("AgentID", IsTag = true)]
public int AgentID { get; set; }
[Column("LoggedState")]
public GeneralLoggedState LoggedState { get; set; }
[Column("PreviousStateDateTime")]
public DateTime? PreviousStateDateTime { get; set; }
[Column("SequenceNumber")]
public int SequenceNumber { get; set; }
[Column("SequenceID")]
public int SequenceID
get
return 100000004 + AgentID;
I’m initing the client and then writing the event with this:
using (var writeApi = client.GetWriteApi())
foreach (var evt in listEvents)
writeApi.WriteMeasurement(bucket, org, WritePrecision.Ns, evt);
// I have the break just to insert 1 record.
break;
I’ve tried with .Flush after .WriteMeasurement but the result is always the same. Any simples query like
from(bucket: "loggedState") |> range(start: 0)
simples return nothing
What am I missing? Do I need to configure something else in InfluxDB?
Thanks in advance
