Not all points being written to InfluxDB using Python
I’m using InfluxDB OSS 2.7 and using the influxdb_client Python library to write data. Right now I am attempting to write a lot of data taken in close intervals to the database, but a lot of the points end up not being written.
import os
from influxdb_client import InfluxDBClient, Point
from influxdb_client.client.write_api import SYNCHRONOUS
from datetime import datetime
import random
import time
DELAY = 0.1
org = "ORG"
client = InfluxDBClient(url="URL", token="TOKEN", org=org)
writeAPI = client.write_api(write_options=SYNCHRONOUS)
points = []
for i in range(21):
    nums = [random.random(),random.random(),random.random()]
    current_time = datetime.now()
    for num, field in zip(nums,["Field1","Field2","Field3"]):
        points.append(Point("MEASUREMENT").tag("DeviceName","DEVICE").field(field,num).time(current_time.astimezone()))
    time.sleep(DELAY)
writeAPI.write("BUCKET",org,points)
The code above simulates my use case, I am collecting data in groups of 3 where each group is very close to one another. When I have a very small delay between groups, not all of the points get written. I am confused about this for two main reasons.
  1. All the points get written when I use a large delay, even though I am writing the entire list at the same time regardless of the delay.
  2. When most of the points don’t get written, there are always one or two groups of 3 that get written. There is never a partial group.
Any ideas for how I can fix this? Is there something I’m missing regarding how InfluxDB handles writes?
i was not able to reproduce your problem with your test script even with 0 delay.
I was looking for point erasing by not enough precision on timestamp but it seems to not be the case.
There is no other “natural” explanation for this in my knowledge.
Thanks for the reply! I tried to recreate this issue on another computer and unfortunately the issue is still occurring. Since the issue didn’t happen for you, this tells me that I probably setup my local database incorrectly. Are there any settings you know of that could be causing this issue for me?
