Suddenly the load on influx started increasing. Can someone help in troubleshooting this?
We have grafana dashboards and few custom scripts so all are http requests
Thanks,
Hello @vi1421,
can you share the logs?
@Anaisdg , There is no error in logs only api requests
@Anaisdg Any help on this ??
@vi1421 I’m not entirely sure where to suggest to start looking for the load increase.
Can you provide a little more background information? Which version in influxdb are you using? What kind of custom scripts are you running? Any other background info that you can think of would likely be helpful as well.
