I was hoping to use InfluxDB dashboarding for a project which requires navigating between dashboards to dig into the data in more detail, is there a way to achieve this?
I would be happy if the way to achieve this was just using relative links to the dashboards in the markdown text, like you can do in GitHub.
Thanks,
James
