I am running Influxdb 2.0 and telegraf as a docker container. I have defined all the plugins in telegraf and it’s working fine. I have one of the [[processors.enum]] plugin and tested and it’s working fine.
Now, I want to have two telegraf.conf files placed inside the telegraf.d directory as:
/etc/telegraf/telegraf.d/kinesis-telegraf.conf
/etec/telegraf/telegraf.d/enum-telegraf.conf
So, I placed my both telegraf.conf inside the telegraf.d directory and put one main telegraf.conf file in default location /etc/telegraf/telegraf.conf. I put output [[outputs.influxdb_v2]] plugin in the main telegraf.conf file but it’s giving errors.
2021-04-06T08:08:38Z I! Using config file: /etc/telegraf/telegraf.conf
2021-04-06T08:08:38Z E! [telegraf] Error running agent: Error: no inputs found, did you provide a valid config file?
2021-04-06T08:08:39Z I! Starting Telegraf 1.18.0
2021-04-06T08:08:39Z I! Using config file: /etc/telegraf/telegraf.conf
2021-04-06T08:08:39Z E! [telegraf] Error running agent: Error: no inputs found, did you provide a valid config file?
2021-04-06T08:08:40Z I! Starting Telegraf 1.18.0
2021-04-06T08:08:40Z I! Using config file: /etc/telegraf/telegraf.conf
2021-04-06T08:08:40Z E! [telegraf] Error running agent: Error: no inputs found, did you provide a valid config file?
2021-04-06T08:08:41Z I! Starting Telegraf 1.18.0
2021-04-06T08:08:41Z I! Using config file: /etc/telegraf/telegraf.conf
2021-04-06T08:08:41Z E! [telegraf] Error running agent: Error: no inputs found, did you provide a valid config file?
2021-04-06T08:08:42Z I! Starting Telegraf 1.18.0
2021-04-06T08:08:42Z I! Using config file: /etc/telegraf/telegraf.conf
2021-04-06T08:08:42Z E! [telegraf] Error running agent: Error: no inputs found, did you provide a valid config file?
2021-04-06T08:08:45Z I! Starting Telegraf 1.18.0
2021-04-06T08:08:45Z I! Using config file: /etc/telegraf/telegraf.conf
2021-04-06T08:08:45Z E! [telegraf] Error running agent: Error: no inputs found, did you provide a valid config file?
2021-04-06T08:08:49Z I! Starting Telegraf 1.18.0
2021-04-06T08:08:49Z I! Using config file: /etc/telegraf/telegraf.conf
2021-04-06T08:08:49Z E! [telegraf] Error running agent: Error: no inputs found, did you provide a valid config file?
2021-04-06T08:08:56Z I! Starting Telegraf 1.18.0
2021-04-06T08:08:56Z I! Using config file: /etc/telegraf/telegraf.conf
2021-04-06T08:08:56Z E! [telegraf] Error running agent: Error: no inputs found, did you provide a valid config file?
In enum-telegraf.conf below content is prsent:
[[processors.enum]]
[[processors.enum.mapping]]
## Name of the field to map. Globs accepted.
## field = "status"
namepass = "om"
## Name of the tag to map. Globs accepted.
tag = "node"
## Destination tag or field to be used for the mapped value. By default the
## source tag or field is used, overwriting the original value.
dest = "site"
## Default value to be used for all values not contained in the mapping
## table. When unset and no match is found, the original field will remain
## unmodified and the destination tag or field will not be created.
# default = 0
## Table of mappings
[processors.enum.mapping.value_mappings]
0005B951 = "mumbai"
0005B952 = "madras"
enum-telegraf.conf and kinesis-telegraf.conf I have tested combing two codes in one telegraf.conf file and it’s working fine.
