Good evening
I am completely new to Influxdb and am trying to send a mqtt string in json format from a raspberry pi to influxdb cloud. Telegraf connects to the database without errors, but no data appears in explorer.
Herewith my config:
[agent]
interval = "2s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
hostname = "raspberrypi"
omit_hostname = false
[[outputs.influxdb_v2]]
urls = ["https://eu-central-1-1.aws.cloud2.influxdata.com"]
token = "jsyaF3KIxs2Mk8qpD8VVhWqbbMKfEUbUPQryZLBkCxlH8ZP7LsvQx76utVV2-A0i3QBLpU1LyrNXc5UU_O7xIQ=="
organization = "MyOrg"
bucket = "MQTT_Rpi_Bucket"
[[inputs.mqtt_consumer]]
servers = ["tcp://81.78.168.179:1883"]
topics = ["rpi/raspberrypi/#"]
data_format = "json"
## Connection timeout for initial connection in seconds
connection_timeout = "30s"
## Username and password to connect MQTT server.
username = "user"
password = "password"
Herewith the startup response from telegraf:
pi@raspberrypi:~ $ telegraf --config https://eu-central-1-1.aws.cloud2.influxdata.com/api/v2/telegrafs/0b65467a1b365000
2023-06-26T22:07:24Z I! Loading config: https://eu-central-1-1.aws.cloud2.influxdata.com/api/v2/telegrafs/0b65467a1b365000
2023-06-26T22:07:24Z I! Starting Telegraf 1.27.1
2023-06-26T22:07:24Z I! Available plugins: 237 inputs, 9 aggregators, 28 processors, 23 parsers, 59 outputs, 4 secret-stores
2023-06-26T22:07:24Z I! Loaded inputs: mqtt_consumer
2023-06-26T22:07:24Z I! Loaded aggregators:
2023-06-26T22:07:24Z I! Loaded processors:
2023-06-26T22:07:24Z I! Loaded secretstores:
2023-06-26T22:07:24Z I! Loaded outputs: influxdb_v2
2023-06-26T22:07:24Z I! Tags enabled: host=raspberrypi
2023-06-26T22:07:24Z I! [agent] Config: Interval:2s, Quiet:false, Hostname:"raspberrypi", Flush Interval:10s
2023-06-26T22:07:24Z I! [inputs.mqtt_consumer] Connected [tcp://81.78.168.179:1883]
This is an example of the json string I am sending:
{"state_topic": "rpi/raspberrypi/cpuload", "name": "raspberrypi CPU Usage", "unit_of_measurement": "%", "value": 5.8, "unique_id": "raspberrypi_cpuload"}
Any help would be greatly appreciated.
